Swan Guest
| Slow sampling (newbie) |
Posted: Thu Sep 27, 2007 10:40 am |
Hi, i'm trying to sample some data from an ADC using SPI.
I'm using a 18f4520, while the ADC is MAX1270.
I need to sample 8 channels at the speed of 2kHz.
As far as i've seen, if i sample 4 channels, everithing goes right, while if i sample all the 8 chs... or it takes longer then 500us, or it just crashes.
I've set the SPI as follow:
setup_spi (SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_4).
here is part of the code:
void process()
unsigned char bDataH0,bDataL0,bDataH1,bDataL1,
bDataH2, bDataL2,bDataH3,bDataL3,
bDataH4, bDataL4,bDataH5,bDataL5,
bDataH6, bDataL6,bDataH7,bDataL7,
if(ADC_On && sample_GO)
select_cs(ADC_DEVICE);
read_sample (0,&bDataH0, &bDataL0);
read_sample (1,&bDataH1, &bDataL1);
read_sample (2,&bDataH2, &bDataL2);
read_sample (3,&bDataH3, &bDataL3);
read_sample (4,&bDataH4, &bDataL4);
read_sample (5,&bDataH5, &bDataL5);
read_sample (6,&bDataH6, &bDataL6);
read_sample (7,&bDataH7, &bDataL7);
select_cs(NONE_DEVICE);
Sample_GO=0; //Sample_GO turns to 1 through an T2 interrupt
I cannot believe that it needs more then 500us to read 8 channels, thus i'm sure i must have done something wrong.
Thank you very much in advance for every help you could give me |
Posted: Thu Sep 27, 2007 11:22 am |
1. Post your compiler version.
2. Post a complete test program, not just pieces of it. Post all #include,
#fuses, #use, etc. statements. The program should be compilable.
Make sure you disable HTML when you post the code. There's a tickbox
for this just below the posting window. |
Posted: Thu Sep 27, 2007 11:55 am |
Here it is...sorry for the comments in italian...
my compiler version is 4.013.
Just to say.. I've got the same result even if i avoid writing the data on rs232, so the problem, for the time beeing, shouldn't be there
Thank you
#INCLUDE <18F4520.H>
#INCLUDE <stdlib.h>
#INCLUDE "Defines.h" // PINS Defines
#Use delay(clock=14745600)
#use RS232(Baud=9600,Xmit=PIN_C6,Rcv=PIN_C7)
unsigned char device;
unsigned char oldDevice;
unsigned char ADC_On=0;
unsigned char sample_GO=0;
unsigned char connectionOn=0;
char bText[16];
byte carattere;
unsigned char received_char=0;
unsigned char inizio=0;
#int_TIMER2
void SamplingTimer()
sample_GO=1;
#int_rda
void serial_interrupt ( )
carattere=getc();
received_char=1;
//////////////////////DRIVER SPI//////////////////////////////////////////////
void Init_SPI()
// Imposto i valori di default
output_high(SPI_SCK);
output_high(SPI_CS_LCD);
output_high(SPI_CS_EEPROM);
output_high(SPI_CS_SD);
output_high(SPI_CS_ADC);
output_low(SPI_SDO);
oldDevice=NONE_DEVICE;
void select_cs( unsigned char device )
// Se e' gia' selezionato esco...
if ( device == oldDevice ) return;
// Seleziono un chip per volta
switch (device) {
case ADC_DEVICE:
SSPEN=0;
setup_spi(SPI_MASTER | SPI_L_TO_H |SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
output_low (SPI_CS_ADC);
SSPEN=1;
case LCD_DEVICE:
SSPEN=0;
setup_spi(SPI_MASTER | SPI_H_TO_L |SPI_XMIT_L_TO_H | SPI_CLK_DIV_64);
// Abilito il correto CS
output_low (SPI_CS_LCD);
output_high (SPI_CS_SD);
output_high (SPI_CS_ADC);
output_high (SPI_CS_EEPROM);
SSPEN=1;
default:
// disabilito i CS
output_low (SPI_RS_LCD);
// Salvo la selezione
oldDevice = device;
////////////////////FINE DRIVER SPI///////////////////////////////////////////
///////////////////INIZIO DRIVER LCD//////////////////////////////////////////
void Init_LCD()
//Accendo la backlight
output_high(LED_BKL);
//attendo 45 ms
delay_ms(45);
select_cs( LCD_DEVICE );
output_low(SPI_RS_LCD);
delay_ms(45);
spi_write(0b00111001);
delay_ms(45);
spi_write(0b00010100);
delay_ms(45);
spi_write(0b01111111);
delay_ms(45);
spi_write(0b01010101);
delay_ms(45);
spi_write(0b01101101);
delay_ms(45);
spi_write(0b00001100);
delay_ms(45);
spi_write(0b00000001);
delay_ms(45);
spi_write(0b00000110);
delay_ms(45);
select_cs( NONE_DEVICE);
// Invia una stringa all'lcd --------------------------------------------------
void write_lcd( char * bTemp, unsigned char bLen, unsigned char bLine )
unsigned char bCounter;
// Seleziono l'LCD
select_cs ( LCD_DEVICE );
delay_us(40);
// Imposto il cursore nella giusta locazione
if ( bLine == 0 )
// [Command] [RS] [R/W] [DB7] [DB6] [DB5] [DB4] [DB3] [DB2] [DB1] [DB0]
// Return Home 0 0 0 0 0 0 0 0 1 0
spi_write(0b00000010);
delay_us(40);
// Set DDRAM Addr 0 0 1 1 0 0 0 0 0 0
// DB6: AC6 -> DDRAM Address
// DB5: AC5 -> DDRAM Address
// DB4: AC4 -> DDRAM Address
// DB3: AC3 -> DDRAM Address
// DB2: AC2 -> DDRAM Address
// DB1: AC1 -> DDRAM Address
// DB0: AC0 -> DDRAM Address
spi_write(0b11000000);
delay_us(40);
// Pronti a scrivere
output_high(SPI_RS_LCD);
delay_us(40);
// Per ogni carattere da spedire...
for ( bCounter = 0; bCounter < 16; bCounter++ )
// Scrivo i dati o gli spazi
if ( bCounter < bLen )
spi_write( bTemp[bCounter]);
spi_write(0x20);
delay_us(40);
// Deseleziono l'LCD
select_cs( NONE_DEVICE );
}//end write_lcd
////////////////////////////FINE DRIVER LCD////////////////////////////////////
///////////////////////INIZIO DRIVER ADC//////////////////////////////////////
void read_sample( unsigned char bChannel, unsigned char *bHigh, unsigned char *bLow )
// Acquisisco il canale X
switch( bChannel ) {
case 0:
spi_write(0b10000100);
case 1:
spi_write(0b10010100);
case 2:
spi_write(0b10100100);
case 3:
spi_write(0b10110100);
case 4:
spi_write(0b11000100);
case 5:
spi_write(0b11010100);
case 6:
spi_write(0b11100100);
case 7:
spi_write(0b11110100);
// Attendo che lo strobe vada a zero
while(input(SPI_STRB_ADC)) delay_cycles( 1 );
// Attendo che lo strobe ritorni ad uno
while (input(!SPI_STRB_ADC) ) delay_cycles( 1 );
*bHigh = spi_read(0b00000000); //Serve solo per mettere da qualche parte i dati dummy
//che l'ADC invia all'inizio
*bLow = spi_read(0b00000000);
/////////////////////////FINE DRIVER ADC//////////////////////////////////////
////////////////////////DRIVER BT////////////////////////////////////////////
void Init_BT()
delay_ms(10);
output_low(PIN_D7);
output_low(BT_PIO4);
output_low(BT_RESET);
delay_ms(10);
output_high(BT_RESET);
// delay_ms(500);
printf("ATSW20,1887,0,0,0\r" ); //472 per 115200, 944 è per una velocità di 230400kbs, 1887 per 460800
set_uart_speed(460800);
printf( "ATSW25,0,0,0,0\r" );
carattere=getc();
putc(carattere);
carattere=getc();
putc(carattere);
carattere=getc();
putc(carattere);
carattere=getc();
putc(carattere);
carattere=getc();
putc(carattere);
carattere=getc();
putc(carattere);
///////////////////////////////FINE DRIVER BT//////////////////////////////////
//////////////////////////////DRIVER POWER////////////////////////////////////
void PSU_ADC_On()
output_high(PSU_ADC);
void PSU_ADC_Off()
output_low(PSU_ADC);
//////////////////////////FUNZIONI DI SERVIZIO/////////////////////////////////
void start_adc()
PSU_ADC_On();
sprintf( bText, "In acquisizione" );
write_lcd( bText, strlen(bText),0);
ADC_On = 1;
output_high(LED_3);
void stop_adc()
PSU_ADC_Off();
ADC_On = 0;
sprintf( bText, "In attesa" );
output_low(LED_3);
disable_interrupts(INT_TIMER2);
void StartConnection()
output_high(LED_2);
delay_us(10);
carattere=getc();
putc(carattere);
if (carattere==0x0A)
if(inizio==0)
inizio=1;
connectionOn=1;
enable_interrupts(int_rda);
void StopConnection()
connectionOn=0;
inizio=0;
disable_interrupts(int_rda);
output_low(LED_2);
carattere=getc();
putc(carattere);
gets(*test);
carattere=getc();
void Init_LED()
output_high(LED_4);
output_high(LED_1);
output_high(LED_3);
output_high(LED_2);
output_low(LED_4);
output_low(LED_3);
output_low(LED_2);
void InterpretCommand()
if (carattere==']') //se si tratta del carattere di start per 2 canali
if(ADC_On==0) //Se non sto già in acquisizione, la avvio
start_adc();
else if (carattere=='£') //Se si tratta del carattere di stop
if(ADC_On==1) //Se sto in acquisizione, mi fermo
stop_adc();
received_char=0;
void Process_System()
if (input(BT_CONN))
if (connectionOn==0) //Ci stiamo connettendo ora, devo ricevere la stringa
//di connessione da parte del dispositivo BT
StartConnection();
// controllo se è stato ricevuto un comando dalla seriale
if (received_char==1) //è arrivato un carattere
InterpretCommand();
if(connectionOn) StopConnection(); //Eravamo Connessi, mi vado ad occupare della chiusura
void Process_User()
long UrielData;
unsigned char valuehigh,valuelow,bDataH0,bDataH1,bDataH2,bDataH3,bDataL0,bDataL1,bDataL2,bDataL3;
if (ADC_On && sample_GO==1)
// Seleziono l'ADC
select_cs( ADC_DEVICE );
// Acquisisco i campioniF
read_sample( 0, &bDataH0, &bDataL0 );
read_sample( 1, &bDataH1, &bDataL1 );
read_sample( 2, &bDataH2, &bDataL2 );
read_sample( 3, &bDataH2, &bDataL2 );
// read_sample( 4, &bDataH3, &bDataL3 );
// read_sample( 5, &bDataH3, &bDataL3 );
// read_sample( 6, &bDataH3, &bDataL3 );
// read_sample( 7, &bDataH3, &bDataL3 );
delay_cycles(1);
printf("[%c%c%c%c",bDataH0,bDataL0,bDataH1,bDataL1);
sample_GO=0;
Init_SPI();
Init_LCD();
Init_BT();
Init_LED();
// PSU_ADC_On();
setup_timer_2(T2_DIV_BY_4,0xE5,2);//Timer associato al campionamento (500us->E5. C8,più basso)
enable_interrupts(GLOBAL); //enable all interrupts
// Scrivo l'LCD
sprintf( bText, "Sistema avviato" );
sprintf( bText, "Hello_1" );
write_lcd( bText, strlen(bText),1);
delay_ms(2000);
sprintf( bText, "Waiting.." );
write_lcd( bText, strlen(bText), 0);
process_System();
process_user();
defines in "defines.h":
#Define LED_1 PIN_E0
#Define LED_2 PIN_E1
#Define LED_3 PIN_E2
#Define LED_4 PIN_C0
#Define BT_PIO4 PIN_D7
#Define BT_RESET PIN_D5
#Define BT_CONN PIN_D6
#Define SPI_SDI PIN_C4
#Define SPI_SDO PIN_C5
#Define SPI_SCK PIN_C3
#Define SPI_CS_LCD PIN_D1
#define SPI_RS_LCD PIN_D0
#define SPI_CS_EEPROM PIN_D4
#define SPI_CS_SD PIN_D3
#define SPI_CS_ADC PIN_D2
#define SPI_STRB_ADC PIN_B0
#define LED_BKL PIN_C1
#define PSU_ADC PIN_A1
#define NONE_DEVICE 0
#define ADC_DEVICE 1
#define LCD_DEVICE 2 |
swan Guest
Posted: Mon Oct 01, 2007 3:28 am |
Sorry... yet i haven't had any answer. Please somebody could give me a hand, a hint, wathever can help me understand what i have done wrong...
Thanks |
