nurquhar
Joined: 05 Aug 2006 Posts: 149 Location: Redditch, UK
Why does removing unused variable cause 'out of ROM' error ? |
Posted: Tue Sep 25, 2007 9:50 pm |
I have a problem with the "out of rom" compiler error. I am using PCM3.249 for PIC16F876A.
Situation is this, I have quite a large program and when it compiles Ok it reports 71% rom usage. However it also gave me a warning that I have an unused variable in main(). A hanging chad from a bit of debugging. So as you would I deleted the redundant statement from main() and recompiled. Wow , it now says I am out of ROM !
If I now put the line in again it compliles fine, except for the warning about 's' being unused. If I change s[6] to be xxx[6] just to be sure the variable is not used it also compliles. If I change it to be or then it also compiles fine. If I have no variable then I am out of ROM !!
The compliler seems to be insisting I have a redundant varible in main(), you'd think removing code would make your app smaller right ?  |
Posted: Tue Sep 25, 2007 9:55 pm |
1. Post the pre-processor statements at the top of your program.
If you are using the CCS Wizard, these statements may be in a small .h
file that's created by the Wizard and is given in an #include statement
at the top of your main program.
2. Post the stats on the percentage of ROM and RAM used. Also post
any information on the number of bytes available in a ROM page.
Get this information from the top of the .LST file (after a successful
compile). The .LST file is in your project directory. |
nurquhar
Posted: Tue Sep 25, 2007 10:02 pm |
Code from the top of main.c. I am not compiling with ICD so the #ORG is in play.
Code: | // CPU Clock Freq
#define FOSC 20000000
//#define FOSC 4000000
#define OSC_DIV 4
//#define BAUDRATE 9600
//#define BAUDRATE 19200
//#define BAUDRATE 33600
#define BAUDRATE 57600
//#define BAUDRATE 115200
//#define BAUDRATE 125000
//#define BAUDRATE 250000
#define INTS_DEBUG
// Use automatice data enable
#define AUTO_DE
#include <16F876A.H>
#device *=16
//#device ICD=TRUE
// Running in ICD mode ?
#if getenv("ICD") == 1
#define __ICD__
#endif
#ifdef __ICD__
#error Compiled For ICD
#else
// Use to reserve memory for Bootloader
#ORG 0x1CC0,0x1FFF {} //for the 8k 16F876/7
#endif
// When defined cutout certain code
//#define DBGSIM
// Use PIC16F876A
#use delay(clock=FOSC)
#priority timer2
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP,NOCPD,NOWRT,NODEBUG
#ifdef AUTO_DE
#use rs232(baud=BAUDRATE, xmit=PIN_C6, rcv=PIN_C7, PARITY=N, BITS=8, ENABLE=PIN_B0, ERRORS)
#else
#use rs232(baud=BAUDRATE, xmit=PIN_C6, rcv=PIN_C7, PARITY=N, BITS=8, ERRORS)
#endif
#define RAND_MAX 1000
#include <stdlib.h>
#include <ctype.h>
#include <string.h>
#include "HexConvert.h"
#include "specreg.h"
#include "basetypes.h"
#define T2_PS T2_DIV_BY_4
#include "timers.h"
#include "bootstrap.h"
#include "crc.c"
#include "eeprom.h"
// Include a Rom Unique ID
//#define SET_ROM_UID 0x00000001
//#include "romuid.h"
#include "AppCommands.h"
// Constant tables
#include "sinewave.h"
char ln[20] ; |
From .LST
Code: | CCS PCM C Compiler, Version 3.249, 33800 26-Sep-07 04:46
Filename: SysLinRGB_01.lst
ROM used: 5620 words (69%)
Largest free fragment is 1216
RAM used: 126 (34%) at main() level
215 (59%) worst case
Stack: 7 worst case (6 in main + 1 for interrupts)
0000: MOVLW 10
0001: MOVWF 0A
0002: GOTO 581
0003: NOP
Posted: Wed Sep 26, 2007 4:37 am |
Is the variable declared in 'main', or is it external (so a global variable, like the 'ln' shown at the end of the stuff you posted)?.
Potentially the latter, implies that the variable will be initialised on boot, and will therefore 'move' the physical location where the 'main' code actually positions itself fractionally.
nurquhar
Posted: Wed Sep 26, 2007 5:50 am |
The variable is the only one declared in main, ie
Code: | void main()
char dummy ;
From some further observations when compiling with and without the extra varible defined the size difference is as follows :
With 'dummy'
Code: | CCS PCM C Compiler, Version 3.249, 33800 26-Sep-07 11:20
Stack: 7 worst case (6 in main + 1 for interrupts) |
Without 'dummy'
Code: | CCS PCM C Compiler, Version 3.249, 33800 26-Sep-07 11:23
ROM used: 5776 words (71%)
Largest free fragment is 972
RAM used: 125 (34%) at main() level
Looking in the LST file and comparing line by line there appear to be extra BCF/BSF instructions when 'dummy' is not used. I think these may be for the RAM bank switching. However I still can't my head around why I need 156 bytes more code to access 1 less variable !! Is there an optimisation level 10 ? |
Posted: Wed Sep 26, 2007 7:18 am |
Depends whether you are using a '18' chip, or a '16'. For the 18 family, there are optimisation levels 10, and 11 on your compiler.
I'd suspect what is happening, is tied up to how ram is used. If (for instance), adding one extra variable to the main, forces memory used in some other routines, to just happen to all shift into one bank, instead of being split across two banks, then the sort of behaviour you are seeing will result. Also remember, that if you have a subroutine, used just once in 'main', then this will almost certainly default to being generated 'inline'. The same comments about bank useage, will apply to these as well.
There was quite a lot of discussion here in the past, about how quite small changes to the order in which variables are declared, can have a major effect on the code size, and efficiency. This appears to be the same behaviour, but triggered in a slightly 'unexpected' way...
