umka
RS 232 |
Posted: Tue Sep 25, 2007 3:07 pm |
i have made a crude laptimer that out puts the most recent 3 lap times and current lap time on a 4line lcd but the rs232 part is not outputting to the computer. the lap time resets and transmits on a button press
here is the code. i have connected TX(pin 25) to through a max 232 to the computers serial port.
Code: | #include <16F877a.H>
#use delay(clock = 4000000)
#use rs232(baud=9600, xmit=PIN_b2,rcv=PIN_b1,BITS =8, PARITY=n, stop=2)
#include <Flex_LCD420.c>
unsigned int8 msec, msec1, msec2, msec3;
unsigned int8 sec, sec1, sec2, sec3;
unsigned int8 min, min1, min2, min3;
unsigned int8 lap_num,but_state;
printf(lcd_putc, "\f");
msec=0; sec=0; min=0; msec1=0; sec1=0; min1=0; msec2=0; sec2=0;
min2=0; msec3=0; sec3=0; min3=0;
lap_num =0;
but_state = input(PIN_B5);
if (but_state == 0)
delay_ms(10);
msec++;
if (msec==100)
sec++;
msec=0;
printf(lcd_putc, "\fCurrent Lap %02u:%02u" ,min,sec);
printf(lcd_putc, "\nLap %02u %02u:%02u:%02u" ,lap_num, min1,sec1,msec1);
printf(lcd_putc, "\nLap %02u %02u:%02u:%02u" ,lap_num-1,min2,sec2,msec2);
printf(lcd_putc, "\nLap %02u %02u:%02u:%02u" ,lap_num-2,min3,sec3,msec3);
if (sec==59)
min++;
sec=255;
if( but_state==1 ) //button PIN B5 goes high
printf("Lap %02u %02u:%02u:%02u\n\r" ,lap_num+1, min,sec,msec);
msec3=msec2; sec3=sec2; min3=min2;
msec2=msec1; sec2=sec1; min2=min1;
msec1=msec; sec1=sec; min1=min;
while(but_state == 1) //waits for button PIN B5 to be go low
delay_ms(1);
lap_num++;
thanks
for any help |
Posted: Tue Sep 25, 2007 3:19 pm |
Er.
You have connected pin 25 to the MAX232, but told the code to use pin 35....
As an 'aside', do you really need to use 2 stop bits?. This means the data cannot be sent by the hardware UART, unless you start fiddling (send 9 bits, and set the 9th bit high).
umka
Posted: Tue Sep 25, 2007 4:01 pm |
no i dont need the 2 stop bits i guess
yes i see its on b2 my mistake
cheers for the help |
