| ailatech
				| sending int16 using RS232 |
				|  Posted: Mon Sep 24, 2007 11:43 pm |   |
				| Hello I have written to the program eeprom sucessfully, and then i need to read those data and send them via the RS232 terminal. The program writes to program eeprom successfully, but it does not send via the rs232.
 The code is:
  	  | Code: |  	  | #include<16f877.h> #fuses NOWDT, HS
 #use delay (clock = 20000000)
 #use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
 void flash (void);
 int16 address;
 for (address = 7168; address<7178; address++)
 write_program_eeprom(address,address%16);
 flash();
 printf("address:%Lu data:%Lu \n\r",address,read_program_eeprom(address));
 void flash (void)
 output_high(PIN_B6);
 delay_ms(1);
 output_low(PIN_B6);
 delay_ms(1);
 what is the wrong with this program?
 Eng. Haytham Shyouk
 B.A. Electronics Engineering
