RF communication problem (serial)
rnome
PostPosted: Thu Sep 20, 2007 9:43 am     Reply with quote
hi everybody
i m trying to send 6 bytes via serial
but whatever i done it didnt work correct.
i wrote this codes for reciever side
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include <lcd.c>
int data[6], x;
int1 data_come=0;
int count=0,index=0;
#INT_RDA
void RDA_isr()
   x=getc();
   if(data_come==1){
            data[index]=x;
          index++;
            if(index>=6){
               index=0;
               data_come=0;
   if(x==85)      //85 is preamble
      count++;       //  if one after the other 5 unit 85 come count
   else            //  reaches 5. else count already 0.
      count=0;
   if(count==5){      //if count equal to 5
      count=0;          //data_come is set to take datas in a array
      data_come=1;
void main( void )
   lcd_init();
   output_high(pin_d2);
   enable_interrupts(int_rda);
   for(;;){
     lcd_gotoxy(1,1);
     printf(lcd_putc, "%u,%u,%u,   \n%u,%u,%u   ",data[0],data[1],data[2],data[3],data[4],data[5]);
i must follow communication protocol of my RF modules
at first 5 bytes preamble must send to wake up RF hardware
after these 5 bytes i can send my 6 bytes
preamble codes are unimportant and i dont want to take them
and these codes for transmitter
#include <16F877.h>
#fuses Xt,NOWDT,NOPROTECT,NOLVP
int d0=10, d1=20, d2=30, d3=40, d4=50, d5=60;
int dizi[6]={10,20,30,40,50,60};
void send()
{int i;
    for(i=0;i<5;i++)
    putc(85);      // 5 byte preamble
    putc(d0);      //datas
    putc(d1);
    putc(d2);
    putc(d3);
    putc(d4);
    putc(d5);
   output_high(pin_B6);
   for(;;)
      send();
      delay_ms(800);
live fast, never rest and do your best
libor
PostPosted: Thu Sep 20, 2007 10:10 am     Reply with quote
At first glance:
A preamble in RF communication should be alternating 0s and 1s, like 0x55. The preamble is used by the receiver module to tune on to the correct datarate.
In your receiver code you rely on receiving the preamble correctly. This is usually not possible, the beginning of the preambles gets lost, this is what they are for.
I think there is a further problem of detecting the byte boundaries correctly.
