TL
| RAM allocation in PIC18F6720 |
Posted: Mon Sep 17, 2007 7:02 am |
1. I have over 150 global RAM variables (containing different types) and would like to allocate them from 0x100. I know #locate can be used to allocate a variable to a RAM location but it is quite tedious for 150 variables. Can someone suggest a more efficient method?
2. How do I assign data in RAM from a starting address to an end address in a function? e.g. Assign addresses 0x100 to 0x105 with 0xFF.
I use PCWH V3.249.
Thank you in advance. |
| Re: RAM allocation in PIC18F6720 |
Posted: Mon Sep 17, 2007 7:26 am |
| TL wrote: | | 1. I have over 150 global RAM variables (containing different types) and would like to allocate them from 0x100. I know #locate can be used to allocate a variable to a RAM location but it is quite tedious for 150 variables. Can someone suggest a more efficient method? | Try to minimize the use of global variables. The compiler can generate more efficient code when you use local variables and the code will be easier to understand and maintain.
For the remaining variables you can use the typemod identifier (replaced by addressmod in the v4 compiler). | Code: | typemod <,,,0x100,0x2ff> LargeMemBank; // Define a large memory area
int8 LargeMemBank GprsRxBuffer[GPRS_RX_SIZE];
int8 LargeMemBank GprsTxBuffer[GPRS_TX_SIZE];
Note that with typemod you only declare a memory region for the variables, you can not specify the exact location of the variables within that region. Be carefull, there is no compiler warning on exceeding the memory region so you will have to check the symbol file for conflicts.
| Quote: | | 2. How do I assign data in RAM from a starting address to an end address in a function? e.g. Assign addresses 0x100 to 0x105 with 0xFF. | Why would you want to do this? Using hard coded addresses like this sounds like bad programming practice. Try to reference the data using standard C mechanisms. | Code: | buf[5] = {0xFF,0xFF,0xFF,0xFF,0xFF};
or
memset(Buf, 0xFF, sizeof(Buf) ); |
TL
Posted: Mon Sep 17, 2007 11:42 am |
Hi Ckielstra,
Thanks for your comments. Yes, I have tried typemod and it works. However, the strategy I was thinking would not work because I cannot assign data to RAM addresses.
I think I’ll use a STRUCTURE to encapsulate all the variables. This way, I can control the data more effectively without knowing the RAM addresses. I’m trying to read data from internal EEPROM to RAM. Also, if the internal EEPROM data is corrupted, I need to copy EEPROM data (backup) from a remote unit to RAM. Therefore, a structure in RAM should be fine. |
Neutone
Posted: Mon Sep 17, 2007 11:44 am |
| TL wrote: | Hi,
I use PCWH V3.249.
You can create a structure and locate the structure.
Using global variable for everything is a trade off. Global variables prevent RAM from being reused so less RAM is available but program code size will also be reduced if variable are not passed to functions because the variables are global. Bank switching can also be reduced if variables are located carefully. |
Hans Wedemeyer
Posted: Tue Sep 18, 2007 2:11 pm |
| Neutone wrote: | | TL wrote: | Hi,
I use PCWH V3.249.
I agree with Neutone use a structure and locate it.
I posted a question a long time ago about the 18F6720 and memory problems. Someone suggested to NOT start the #locate below 0X300 which will prevents conflicts with the CCS compiler. Of course that was a long time ago.
However once I did that the memory problems were fixed... |
