Variable PWM
HOHOHAHA
Variable PWM
PostPosted: Sun Sep 16, 2007 5:09 pm     Reply with quote
hello,
Can any one suggest me if at all is it possible to generate PWM of the range 35KHz to 37kHz with 0.1kHz increase within an infinite loop where I would be checking some o/p from my sensor is high or not. I use PIC 16f877A and 20Mhz crystal. My compiler version is 4.023.
If any one can show me some example it would be appreciated.
PostPosted: Sun Sep 16, 2007 5:18 pm     Reply with quote
Normally, PWM means the frequency of the signal is constant, but the
"duty cycle" (duration) of the positive pulse changes.
Look at the image half-way down this page:
http://www.embedded.com/story/OEG20010821S0096
It shows timing diagrams of 10%, 50%, and 90% duty cycle for
the PWM waveform.
This is probably what you really want.
HOHOHAHA
Not really
PostPosted: Sun Sep 16, 2007 10:31 pm     Reply with quote
setup_ccp1(CCP_PWM);   // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_16, 255, 1);   // Setup for 1465 Hz
set_pwm1_duty(128);                    //  50% duty cycle
Let this be the code .. then line number 2 decides what the freuency would be set to ? right ? ( I am a bit confused after viewing your reply)
the next line
set_pwm1_duty(128);
sets the PWM duty cycle, I thought the duty cycle usually denoted the average voltage that is going to be provided by the PIC, it it is 255 for 5V and 0 for 0V.
Till today what I understood is :
let a PIC have been configured for certain freuency, the the duty cycle will define the voltage that will be provided when the o/p is high( as it is varying due to set frequency)
I am throughly confused please explain
PostPosted: Mon Sep 17, 2007 2:32 pm     Reply with quote
Tell us what your project is. Tell us what you want to use PWM for.
Is it to run a motor ? Is it to control the brightness of an LED ?
Post details about the project.
HOHOHAHA
My project
PostPosted: Mon Sep 17, 2007 4:53 pm     Reply with quote
In India we don't have any good distance ranging sensor. So I use TSOP1738 IR sensor to detect the IR radiated with modulated frequency of 35 to 40 KHz. Now the TSOP1738 responses to a greater range to 38KHz modulation about a distance of 2m but when I modulate it to 35.5Khz it gives me a range of 10cm, hence by changing(without again reprogramming) the generated frequency I want to detect the distance of the object placed away from the sensor.
