how to modify code and solve warning "prevent re-entran
whung.john
PostPosted: Sat Sep 08, 2007 11:59 am     Reply with quote
hi my friends.
Sad
i try practice a program. but i compiled.
warning area display some informations.
information follow as:
interrupts disable during call to prevent re_entracce .[sendbit_1621]
interrupts disable during call to prevent re_entracce .[write_1621]
interrupts disable during call to prevent re_entracce .[@delay_ms1]
interrupts disable during call to prevent re_entracce .[@div88]
first question follow as:
i search my practice code.but only find interrupts timer1 have use "sendbit_1621" and "write_1621 "command.
i try addtion the "sendbit_1621" and "write_1621" into interrupt(timer1).
but thread become big from compile information.
so i dont know how to solve question.
second question.
the other warning ([@delay_ms1] and .[@div88]).
i cant find error code. have body can solve error area and teach me how to modify thread.
third question.
how can i save memory (ram and rom).because i compiled get use much
ram and rom .
my all thread follow as,hope to my friends can teach me .
#include <16F73.h>
#FUSES NOWDT, XT, NOPUT, NOPROTECT, NOBROWNOUT
#define DAT PIN_C7
#define WR PIN_B0
#define bias 0x52
#define system 0x02
#define system_dis 0x00
#define lcdon 0x06
#define lcdoff 0x04
#define normal 0xc6
void sendbit_1621(unsigned char data,unsigned char cnt);
void senddatabit_1621(unsigned char data,unsigned char cnt);
void sendcmd(unsigned char command);
void write_1621(unsigned char addr,unsigned char data);
void writeall_1621(unsigned char addr,unsigned char *p,unsigned char cnt );
void all_display(void);
void ht1621_init(void);
void cls(void);
void kk_point(void);
void zero_timer(void);
void first_display(void);
void power_porg(void);
void timer_prog(void);
unsigned int seconds=0,mins=0;
const unsigned int setmins[7]={0,30,25,20,15,10,5};
unsigned timer_key1=0,timer_key2=0;
unsigned int setmins_key=0;
int16 int_count=0;
BYTE plag;
unsigned int keyscan;
unsigned int8 control_motorkey=0;
BYTE power_onoff=0;
const unsigned char timer_c1[2][10]={0x07,0x06,0x03,0x07,0x06,0x05,0x04,0x07,0x07,0x07,0x0D,0x00,0x0E,0x0a,0x03,0x0b,0x0f,0x00,0x0f,0x03};
unsigned char i;
for (i=0;i<cnt;i++)
if ((data&0x80)==0) output_low(DAT);
else output_high(DAT);
output_low(wr);
delay_cycles(1);
output_high(wr);
data<<=1;
unsigned char i;
for (i=0;i<cnt>>=1;
output_low(PIN_c5);
output_low(PIN_c6);
sendbit_1621(0x80,4);
sendbit_1621(command,8);
output_high(wr);
output_high(PIN_c5);
output_high(PIN_c6);
output_low(PIN_c5);
output_low(PIN_c6);
sendbit_1621(0xa0,3);
sendbit_1621(addr,6);
senddatabit_1621(data,4);
unsigned char i;
output_low(PIN_c5);
output_low(PIN_c6);
for (i=1;i<cnt;i++,p++)
senddatabit_1621(*p,8);
void cls(void)
unsigned int j;
for(j=0;j<128;j=j+3)
write_1621(j,0x00);
unsigned int j;
for(j=0;j<128>0)||(timer_key2>0))
if (timer_key1>0)
timer_key1=((setmins[setmins_key]-mins)/10);
timer_key2=((setmins[setmins_key]-mins)%10);
if (power_onoff==1)
disable_interrupts(INT_timer1);
zero_timer();
enable_interrupts(INT_timer1);
++setmins_key;
timer_key1=(setmins[setmins_key]/10);
timer_key2=(setmins[setmins_key]%10);
write_1621(36,timer_c1[0][timer_key1]);
write_1621(32,timer_c1[1][timer_key1]);
write_1621(44,timer_c1[0][timer_key2]);
write_1621(40,timer_c1[1][timer_key2]);
delay_ms(250);
if (setmins_key==6)
setmins_key=0;
void power_prog(void)
if (power_onoff==0)
sendcmd(lcdon);
first_display();
power_onoff=1;
delay_ms(250);
zero_timer();
setmins_key=0;
sendcmd(lcdoff);
power_onoff=0;
delay_ms(250);
cls();
unsigned int j;
const unsigned int keybord[3][2]= {1,0,
0,1,
1,1};
ht1621_init();
all_display();
for (j=1;j<=3;j++)
sendcmd(lcdon);
sendcmd(lcdoff);
cls();
setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_1 );
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
for (keyscan=0;keyscan<3;keyscan++)
output_bit(PIN_c5,keybord[keyscan][0]);
output_bit(PIN_c6,keybord[keyscan][1]);
if (!input(pin_b1) && (keyscan==2))
cls();
if (!input(pin_b2) && (keyscan==2))
write_1621(60,0x08);
if (!input(pin_b3) && (keyscan==2))
write_1621(60,0x04);
if (!input(pin_b4) && (keyscan==2))
write_1621(60,0x02);
if (!input(pin_b7) && (keyscan==0))
power_prog();
if (!input(pin_b7) && (keyscan==1))
timer_prog();
PostPosted: Sat Sep 08, 2007 1:52 pm     Reply with quote
First, repost the question, using the 'code' controls round your code, and setting the tickbox 'disable HTML in this post'. Without these being done, your code is unreadable...
I also can't see the interrupt handlers in the post.
These are only warnings, and are not serious. Fixing them may well not be worthwhile (it means duplicating _all_ code that is used both in the interrupt handler and outside), and for code performing hardware operations, the interrupts _must_ be disabled, if you are to avoid having such controls in the main, interrupted by the one in the interrupt handler.
WHUNG.JOHN
again display my code.
PostPosted: Sun Sep 09, 2007 4:54 am     Reply with quote
#include <16F73.h>
#define DAT PIN_C7
#define WR PIN_B0
#define bias 0x52
#define system 0x02
#define lcdon 0x06
#define lcdoff 0x04
#define normal 0xc6
void cls(void);
int16 int_count=0;
BYTE plag;
BYTE power_onoff=0;
unsigned char i;
for (i=0;i<cnt;i++)
output_low(wr);
delay_cycles(1);
output_high(wr);
data<<=1;
unsigned char i;
for (i=0;i<cnt>>=1;
output_low(PIN_c5);
output_low(PIN_c6);
output_high(wr);
output_low(PIN_c5);
output_low(PIN_c6);
unsigned char i;
output_low(PIN_c5);
output_low(PIN_c6);
void cls(void)
unsigned int j;
write_1621(j,0x00);
unsigned int j;
if (timer_key1>0)
if (power_onoff==1)
zero_timer();
++setmins_key;
delay_ms(250);
if (setmins_key==6)
setmins_key=0;
if (power_onoff==0)
sendcmd(lcdon);
first_display();
power_onoff=1;
delay_ms(250);
zero_timer();
setmins_key=0;
sendcmd(lcdoff);
power_onoff=0;
delay_ms(250);
cls();
unsigned int j;
0,1,
1,1};
ht1621_init();
all_display();
for (j=1;j<=3;j++)
sendcmd(lcdon);
sendcmd(lcdoff);
cls();
setup_adc(ADC_OFF);
cls();
power_prog();
timer_prog();
WHUNG.JOHN
SORRY MY FRIENDS.THIS POST IS MY CODE CLEARLY.
PostPosted: Sun Sep 09, 2007 5:07 am     Reply with quote
MY FRIENDS MY CODE FOLLOW AS
#include <16F73.h>
#define DAT PIN_C7
#define WR PIN_B0
#define bias 0x52
#define system 0x02
#define lcdon 0x06
#define lcdoff 0x04
#define normal 0xc6
void cls(void);
int16 int_count=0;
BYTE plag;
BYTE power_onoff=0;
unsigned char i;
for (i=0;i<cnt;i++)
output_low(wr);
delay_cycles(1);
output_high(wr);
data<<=1;
unsigned char i;
for (i=0;i<cnt>>=1;
output_low(PIN_c5);
output_low(PIN_c6);
output_high(wr);
output_low(PIN_c5);
output_low(PIN_c6);
unsigned char i;
output_low(PIN_c5);
output_low(PIN_c6);
void cls(void)
unsigned int j;
write_1621(j,0x00);
unsigned int j;
if (timer_key1>0)
sendcmd(bias);
sendcmd(system);
sendcmd(lcdoff);
 seconds=0;
 mins=0;
 int_count=0;
 timer_key1=0;
 timer_key2=0;
void kk_point(void)
        if (plag==0)
              //write_1621(44,0x08+timer_c1[0][mins]);
              //write_1621(40,timer_c1[1][mins]);
              write_1621(44,0x08+timer_c1[0][timer_key2
              plag=1;
              //write_1621(44,0x00+timer_c1[0][mins]);
              write_1621(44,0X00+timer_c1[0][timer_key2]);
              write_1621(40,timer_c1[1][timer_key2]);//
              plag=0;
  write_1621(44,timer_c1[0][timer_key2]);/
#int_timer1
void timer1_isr(void)
      set_timer1(55536);
   if(int_count++==100
      seconds++;
      int_count=0;
      kk_point();
    if (seconds==60)
          mins++;
          seconds=0;
                     if ((timer_key1>0)||(timer_key2>0))
             if (timer_key1>0
if (power_onoff==1)
zero_timer();
++setmins_key;
delay_ms(250);
if (setmins_key==6)
setmins_key=0;
if (power_onoff==0)
sendcmd(lcdon);
first_display();
power_onoff=1;
delay_ms(250);
zero_timer();
setmins_key=0;
sendcmd(lcdoff);
power_onoff=0;
delay_ms(250);
cls();
unsigned int j;
0,1,
1,1};
ht1621_init();
all_display();
for (j=1;j<=3;j++)
sendcmd(lcdon);
sendcmd(lcdoff);
cls();
setup_adc(ADC_OFF);
cls();
power_prog();
timer_prog();
PostPosted: Sun Sep 09, 2007 6:33 am     Reply with quote
1) If you become a member of this forum you can edit your posts so you don't have to do a new post everytime you make an error. It will also show more respect to us and tell us you are a serious visitor. This will all help in getting you quicker and better answers.
2) Your post is still messed up because you didn't set the option 'disable HTML in this post'. Example
for (i=0;i<cnt>>=1;
3) The compiler warning you have is caused by the use of the function write_1621() both inside and outside the interrupt handler. To avoid errors the compiler has added code to disable the interrupts when this function is called. This is one way to solve the problem and you can leave it like that.
whung.john
thanks u very much
PostPosted: Tue Sep 11, 2007 8:03 am     Reply with quote
Very Happy
my friends. the question is solved.
i find my interrupts re-entrance to other thread.
thank u very much
