PWM frequency versus resolution set up
PostPosted: Fri Sep 07, 2007 1:32 pm     Reply with quote
I have already sent this question to CCS support, but I not sure I will get a quick answer, so I decided to post it here as well, as I am sure I'll get a quicker answer.
I am trying to set-up my pwm frequency on a project using a PIC18F4620, my clock frequency is 10.0 MHz and I need to get 7.184 KHz (or anything between 6 to 7.5 KHz) with a 10 bit pwm resolution. Using the PIC setup WIZ it does show that this is accomplishable at 10 bits of resolution and that the timer2 configuration is: setup_timer_2(T2_DIV_BY_4,86,1) However, when I use this configuration, although I am getting the right frequency, the resolution is way off, it is something less than 7 bits? I have also done the calculations using the PIC data sheet and if I set the PR2 register to 86, timer 2 prescaler to divide by 4 (same as above) it should work?, the actual frequency is 7267 and if we calculate the pwm resolution it is well within 10 bits.
for the above, If we use PWM res = ln(Fosc/Fpwm) / ln(2) = 10.44 bits
Also the PWM freq above is well within the counter constraints for timer2 using a 10 MHz clock
I'm I missing something? can anyone shed some light? Confused
PostPosted: Fri Sep 07, 2007 1:36 pm     Reply with quote
Post the statement that sets the PWM duty cycle. Also post the
declaration of the variable used in that statement.
cbarberis
PostPosted: Fri Sep 07, 2007 2:10 pm     Reply with quote
I declare a variable as follows:
unsigned int16 k= 512; // set it to 50% duty
set_pwm1_duty(k);
// the above gives me a fully saturated output out of CCP2?
void init()
set_tris_a(0xFF); // RA7-RA0 -> in,in,in,in,in,in,in,in
set_tris_b(0xC7); // RB7-RB0 -> in,in,out,out,out,in,in,in
set_tris_c(0x91); // RC7-RC0 -> in,out,out,in,out,out,out,in
set_tris_d(0xF0); // RD7-RD0 -> in,in,in,in,out,out,out,out ***Reconfigures in LCD driver
set_tris_e(0xf); // RE3-RE0 -> in,in,in,in
setup_adc_ports(AN0_TO_AN1|VSS_VDD);
setup_psp(PSP_DISABLED);
//setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4|SPI_XMIT_L_TO_H |SPI_SS_DISABLED);
port_b_pullups(TRUE);
setup_wdt(WDT_ON);
//setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_64|RTCC_8_bit); //will overflow at 154Hz or every 6.5mS
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); //will overflow at 38Hz or every 26.2mS
setup_timer_2(T2_DIV_BY_4,86,1); // generates pwm freq of 7.267 KHz with 10 bit res
// setup_timer_2(T2_DIV_BY_1,255,1); // generates pwm freq of 9.77KHz with 10 bit res works ok
//setup_timer_4(T4_DISABLED,0,1);
setup_ccp1(CCP_PWM);
setup_ccp2(CCP_PWM);
ext_int_edge( H_TO_L); // Set up PIC18 EXT
ext_int_edge( 1, H_TO_L); // Set up PIC18 EXT2
//disable_interrupts(INT_TIMER0);
disable_interrupts(INT_TIMER1);
disable_interrupts(INT_EXT);
//enable_interrupts(INT_EXT);
setup_vref(FALSE);
setup_low_volt_detect(FALSE);
setup_oscillator(False);
//enable_interrupts(INT_RB);
// enable_interrupts(INT_EXT1);
enable_interrupts(INT_RDA);
disable_interrupts(INT_EXT1);
//disable_interrupts(GLOBAL);
InitBothPots();
lcd_init(); // initialize LCD
store_tripleline(); // store triple line for first page in lcd CGRAM
write_to_pot_R1(0);
set_pwm1_duty(0);
set_pwm2_duty(0);
FAN = OFF;
If I do the following to just continuosly test the pwm output
int8 i;
init();
set_pwm1_duty(128);
while(1) restart_wdt() }
I get approximately a 75% ON time duty ????
PostPosted: Fri Sep 07, 2007 2:20 pm     Reply with quote
90% of your posted code has nothing to do with the PWM problem.
See my post about halfway down this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=18259
PostPosted: Fri Sep 07, 2007 3:20 pm     Reply with quote
Thank you PCM programmer.
I realized I should just pasted only a couple of things of my init() which is mostly unrelated to the problem.
The post you sent me answer the issue, I think this is something that should be indicated on the app notes, the value of PR2 prescaler is critical to the pwm frequency resolution. Surprised
Kenny
PostPosted: Fri Sep 07, 2007 4:38 pm     Reply with quote
Edited to fix error:
The number of bits resolution calculation needs the prescaler value
ie. log((Fosc/Prescaler)/Fpwm) / log(2)
The prescaler is 4 in this case, and this works out to be 8.443 bits.
2^8.443 = 348 steps.
An easier way to get the number of steps is as follows.
Timer 2 is concatenated with two other bits, so the number of steps is (PR2 + 1) * 4. This is independent of the prescaler.
With PR2 = 86
Number of steps is (86+1)*4 = 348
Note that when setting a constant less than 256 the compiler will need to be told to generate code for 10 bit pwm either by adding an 'L' to the value or casting it to an int16.
eg. set 50% duty cycle
set_pwm1_duty(174L);
