I2C FORCE_HW problems
Nopnop
PostPosted: Fri Aug 10, 2007 3:30 pm     Reply with quote
Hi, I am French, sorry for my English.
If I have understood the I2C parameter FORCE_HW manage the I2C bus automatically.
When I execute this code I must add a delay_ms(5) after I2C_stop() for my data is written in EEPROM 24FC1025.
Can you tell me if the delay_ms(5) after I2C_stop is obligatory.
Thanks for your answers.
vAdresse=0x0000;
While(true)
i2c_start();
i2c_write(0xa0); // Contrôle
i2c_write(vAdresse>>8); // Adresse
i2c_write(vAdresse); // Adresse
i2c_write(vData>>8); // Data poids faible
i2c_write(vData); // Data poids fort
i2c_stop();
PostPosted: Fri Aug 10, 2007 3:36 pm     Reply with quote
Download the eeprom data sheet.
http://ww1.microchip.com/downloads/en/DeviceDoc/21941B.pdf
Look at the Write Cycle Time (Param No. 17 on page 3). It's 5 ms.
The CCS driver uses "Ack Polling". This may allow the wait for
the write operation to be shorter than 5 ms. Why not use the
CCS driver ? Here's the file location:
c:\Program Files\PICC\Drivers\241025.c
Nopnop
PostPosted: Tue Sep 04, 2007 2:47 pm     Reply with quote
Hi, PCM Programmer thanks for the solution of EEPROM.
Now I have a problem between two PIC 18F452.
When I send the address and data I don’t have the good result.
I have 00 00
And 01 90
And 90 90
Normally I should have
00 00
90 01
90 02
90 03
If anyone have an ideas
Master code
#include <18F452.h>
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use i2c(MASTER, SCL=PIN_C3, SDA=PIN_C4, FAST=400000, FORCE_HW)
int data;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_wdt(WDT_OFF);
   set_tris_A(0b00010000);                   // Paramétrage du port A
   set_tris_B(0b00110000);                   // Paramétrage du port B
   set_tris_C(0b10011001);                   // Paramétrage du port C
   set_tris_D(0b00000000);                   // Paramétrage du port D
   set_tris_E(0b00000000);
   data=0x01;
   delay_ms(2000);
   while(true)
      i2c_start();
      i2c_write(0x90);  // Adresse
      i2c_write(data++);   // Data
      i2c_stop();
Slave code
#include <18F452.h>
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, PUT, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use i2c(SLAVE, ADDRESS=0x90, SCL=PIN_C3, SDA=PIN_C4, FAST=400000, FORCE_HW)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#include <LCD_nopnop.C>
int valeur1;
int valeur2;
#INT_SSP
void SSP_INT()
   byte incoming,state;
   state=i2c_isr_state();
   if(state<0x80)
      incoming=i2c_read(1);
      if(state == 1)          //First received byte is address
         valeur1=incoming;
      if(state == 2)          //Second received byte is data
         valeur2=incoming;
   if (state>=0x80)
      i2c_write(0x45);
   setup_adc(ADC_OFF);
   setup_wdt(WDT_OFF);
   enable_interrupts(INT_SSP);
   clear_interrupt(INT_SSP);
   output_A(0);
   output_B(0);
   output_C(0);
   output_E(0);
   set_tris_A(0b00000001);
   set_tris_B(0b10111111);
   set_tris_C(0b10111011);
   set_tris_E(0b00000100);
   lcd_init();                               // Init ecran LCD
   valeur1=0;
   valeur2=0;
   while(true)
      lcd_gotoxy(1,2);
      printf(LCD_PUTC,"%x",valeur1);
      lcd_gotoxy(4,2);
      printf(LCD_PUTC,"%x",valeur2);
made by www.nopnop.fr
PostPosted: Tue Sep 04, 2007 3:29 pm     Reply with quote
Don't try to run the slave at 400 KHz. Change the i2c Master clock
speed to 100 KHz.
Nopnop
PostPosted: Wed Sep 05, 2007 2:09 pm     Reply with quote
Hi I have tried your advice with SLOW or FAST=100000.
The result is
00 00
01 00
02 00
03 00
It is better but I don’t know why the data is first and address second. Normally it is the opposite.
PostPosted: Wed Sep 05, 2007 2:23 pm     Reply with quote
The address arrives when state==0. You are not printing this. Valeur2, remains '0', from when the chip woke up. You need:
   if(state<0x80)
      if(state == 0)          //First received byte is address
         valeur1=incoming;
      if(state == 1)          //Second received byte is data - '1' = first data
      {                           //byte received.
         valeur2=incoming;
Nopnop
PostPosted: Thu Sep 06, 2007 2:17 pm     Reply with quote
Thanks for your help
I have tried your solution but the result is
01 01
02 02
03 03
04 04
Do you know why address does not appear perhaps the FORCE_HW parameter?
