composite device: enum failed
Goto page 1, 2  Next
NicolasC
PostPosted: Sat Aug 11, 2007 2:15 pm     Reply with quote
Hil all
I'm trying to make a CDC+HID+KBD device but enumeration fails:
After the configuration descriptor is sent, the comm stops :
1   in down   n/a   0.001 GET_DESCRIPTOR_FROM_DEVICE
1   in up     n/a   0.003 CONTROL_TRANSFER   12 01 00 02 00 00 00 40   0x00000000
2   in down   n/a   0.003 GET_DESCRIPTOR_FROM_DEVICE
2   in up     n/a   0.005 CONTROL_TRANSFER   09 02 7c 00 04 01 00 c0   0x00000000
3   in down   n/a   0.005 GET_DESCRIPTOR_FROM_DEVICE
3   in up     n/a   0.008 CONTROL_TRANSFER   09 02 7c 00 04 01 00 c0   0x00000000
The content of the last packet displayed by snoopy is exactly was is define in the USB_CONFIG_DESC structure.
   ///  HID Report.  Tells HID driver how to handle and deal with
   ///  received data.  HID Reports can be extremely complex,
   ///  see HID specifcation for help on writing your own.
   ///  First it defines a block for the first interface for a mouse
   ///  protocol.  Second it defines a block for the second interface
   ///  for a keyboard protocol.
   const char USB_CLASS_SPECIFIC_DESC[] = {
    //hid report descriptor for interface 0 (joystick)
      0x05, 0x01,       // Usage Page = Generic Desktop                 ==0,1
      0x09, 0x04,       // Usage = Joystick                             ==2,3
      0xA1, 0x01,       // Collection = Application                     ==4,5
        0x09, 0x33,       // Usage (Rx)                                 ==6,7
        0x09, 0x34,       // Usage (Ry)                                 ==8,9
        0x09, 0x35,       // Usage (Ry)                                 ==10,11
        0x09, 0x36,       // Usage (Slider)                             ==12,13
        0x15, 0x00,       // Logical  Minimum (0)                       ==14,15
        0x26, 0xFF,0x03,  // Logical  Maximum (1023)                    ==16,17,18
        0x35, 0x00,       // Physical Minimum (0)                       ==19,20
        0x46, 0xFF,0x03,  // Physical Maximum (1023)                    ==21,22,23
        0x75, 0x0A,       // Report Size (10)  10 bits                  ==24,25
        0x95, 0x04,       // Report Count (4)                           ==26,27
        0x81, 0x02,       // Input (Data,Var,Abs)                       ==28,29
      0xC0,              // End Collection                              ==30
    //hid report descriptor for interface 1 (keyboard)
      0x05, 0x01, //usage page (generic desktop)                        ==31, 32
      0x09, 0x06, //usage (keyboard)                                    ==33, 34
      0xA1, 0x01, //collection (application)                            ==35, 36
        0x05, 0x07, //usage page (key codes)                            ==37, 38
        0x19, 0xE0, //usage min (224)                                   ==39, 40
        0x29, 0xE7, //usage max (231)                                   ==41, 42
        0x15, 0x00, //logical min (0)                                   ==43, 44
        0x25, 0x01, //logical max (1)                                   ==45, 46
        0x75, 0x01, //report size (1)                                   ==47, 48
        0x95, 0x08, //report count (8)                                  ==49, 50
        0x81, 0x02, //input (data, variable, absolute) [modifier byte]  ==51, 52
        0x95, 0x01, //report count (1)                                  ==53, 54
        0x75, 0x08, //report size (8)                                   ==55, 56
        0x81, 0x01, //input (constant) [reserved byte]                  ==57, 58
        0x95, 0x05, //report count (5)                                  ==59, 60
        0x75, 0x01, //report size (1)                                   ==61, 62
        0x05, 0x08, //usage page (page# for leds)                       ==63, 64
        0x19, 0x01, //usage min (1)                                     ==65, 66
        0x29, 0x05, //usage max (5)                                     ==67, 68
        0x91, 0x02, //output (data, var, abs) [led report]              ==69, 70
        0x95, 0x01, //report count (1)                                  ==71, 72
        0x75, 0x03, //report size (3)                                   ==73, 74
        0x91, 0x01, //output (constant) [led report padding]            ==75, 76
        0x95, 0x05, //report count (5)                                  ==77, 78
        0x75, 0x08, //report size (8)                                   ==79, 80
        0x15, 0x00, //logical min (0)                                   ==81, 82
        0x25, 0x65, //logical max (101)                                 ==83, 84
        0x05, 0x07, //usage page (key codes)                            ==85, 86
        0x19, 0x00, //usage min (0)                                     ==87, 88
        0x29, 0x65, //usage max (101)                                   ==89, 90
        0x81, 0x00, //input (data, array)                               ==91, 92
      0xC0        //end collection                                      ==93
   //if a class has an extra descriptor not part of the config descriptor,
   // this lookup table defines where to look for it in the const
   // USB_CLASS_SPECIFIC_DESC[] array.
   //first element is the config number (if your device has more than one config)
   //second element is which interface number
   //set element to 0xFFFF if this config/interface combo doesn't exist
   //Idx in USB_CLASS_SPECIFIC_DESC
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP[USB_NUM_CONFIGURATIONS][2] =
   //config 1
      //interface 0
         0,
      //interface 1
         31
   // this lookup table defines the size of that descriptor.
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[USB_NUM_CONFIGURATIONS][2] =
   //config 1
      //interface 0
         31,
      //interface 1
         63
///   start config descriptor
///   right now we only support one configuration descriptor.
///   the config, interface, class, and endpoint goes into this array.
   #DEFINE USB_TOTAL_CONFIG_LEN      124//67  //config+interface+class+endpoint+endpoint (2 endpoints)
   const char USB_CONFIG_DESC[] = {
   //IN ORDER TO COMPLY WITH WINDOWS HOSTS, THE ORDER OF THIS ARRAY MUST BE:
      //    config(s)
      //    interface(s)
      //    class(es)
      //    endpoint(s)
   //config_descriptor for config index 1
         USB_DESC_CONFIG_LEN, //length of descriptor size                                 ==0
         USB_DESC_CONFIG_TYPE, //constant CONFIGURATION (CONFIGURATION 0x02)              ==1
         USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config              ==2,3
         4, //number of interfaces this device supports                                   ==4
         0x01, //identifier for this configuration.  (IF we had more than one configurations)      ==5
         0x00, //index of string descriptor for this configuration                        ==6
         0xC0, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1         ==7
         0x32, //maximum bus power required (maximum milliamperes/2)  (0x32 = 100mA)      == 8
   //interface descriptor 0 (comm class interface)
         USB_DESC_INTERFACE_LEN, //length of descriptor                                   ==9
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)                   ==10
         0x00, //number defining this interface (IF we had more than one interface)       ==11
         0x00, //alternate setting                                                        ==12
         1, //number of endpoints                                                         ==13
         0x02, //class code, 02 = Comm Interface Class                                    ==14
         0x02, //subclass code, 2 = Abstract                                              ==15
         0x01, //protocol code, 1 = v.25ter                                               ==16
         0x00, //index of string descriptor for interface                                 ==17
   //class descriptor [functional header]
         5, //length of descriptor                                                        ==18
         0x24, //dscriptor type (0x24 == )                                                ==19
         0, //sub type (0=functional header)                                              ==20
         0x10,0x01, //        ==21,22 //cdc version
   //class descriptor [acm header]
         4, //length of descriptor                                                        ==23
         0x24, //dscriptor type (0x24 == )                                                ==24
         2, //sub type (2=ACM)                                                            ==25
         2, //capabilities        ==26  //we support Set_Line_Coding, Set_Control_Line_State, Get_Line_Coding, and the notification Serial_State.
   //class descriptor [union header]
         5, //length of descriptor                                                        ==27
         0x24, //dscriptor type (0x24 == )                                                ==28
         6, //sub type (6=union)                                                          ==29
         0, //master intf        ==30  //The interface number of the Communication or Dat a Cl [spam] interface, designated as the masteror controlling interface for the union.
         1, //save intf0        ==31  //Interface number of first slave or associated interface in the union. *
   //class descriptor [call mgmt header]
         5, //length of descriptor                                                        ==32
         0x24, //dscriptor type (0x24 == )                                                ==33
         1, //sub type (1=call mgmt)                                                      ==34
         0, //capabilities        ==35  //device does not handle call management itself
         1, //data interface                                                              ==36  //interface number of data class interface
   //endpoint descriptor
         USB_DESC_ENDPOINT_LEN, //length of descriptor                                    ==37
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)                      ==38
         USB_CDC_COMM_IN_ENDPOINT | 0x80, //endpoint number and direction                 ==39
         0x03, //transfer type supported (0x03 is interrupt)                              ==40
         USB_CDC_COMM_IN_SIZE,0x00, //maximum packet size supported                       ==41,42
         250,  //polling interval, in ms.  (cant be smaller than 10)                      ==43
   //interface descriptor 1 (data class interface)
         USB_DESC_INTERFACE_LEN, //length of descriptor                                   ==44
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)                   ==45
         0x01, //number defining this interface (IF we had more than one interface)       ==46
         0x00, //alternate setting                                                        ==47
         2, //number of endpoints                                                         ==48
         0x0A, //class code, 0A = Data Interface Class                                    ==49
         0x00, //subclass code                                                            ==50
         0x00, //protocol code                                                            ==51
         0x00, //index of string descriptor for interface                                 ==52
         USB_DESC_ENDPOINT_LEN, //length of descriptor                                    ==53
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)                      ==54
         USB_CDC_DATA_OUT_ENDPOINT, //endpoint number and direction (0x02 = EP2 OUT)      ==55
         0x02, //transfer type supported (0x02 is bulk)                                   ==56
         USB_CDC_DATA_OUT_SIZE & 0xFF, (USB_CDC_DATA_OUT_SIZE >> 8) & 0xFF, //maximum packet size supported  ==57, 58
         250,  //polling interval, in ms.  (cant be smaller than 10)                      ==59
         USB_DESC_ENDPOINT_LEN, //length of descriptor                                    ==60
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)                      ==61
         USB_CDC_DATA_IN_ENDPOINT | 0x80, //endpoint number and direction (0x82 = EP2 IN) ==62
         0x02, //transfer type supported (0x02 is bulk)                                   ==63
         USB_CDC_DATA_IN_SIZE & 0xFF, (USB_CDC_DATA_IN_SIZE >> 8) & 0xFF, //maximum packet size supported    ==64, 65
         250,  //polling interval, in ms.  (cant be smaller than 10)                      ==66
   //interface descriptor 2 (HID)
         USB_DESC_INTERFACE_LEN, //length of descriptor                                   ==67
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)                   ==68
         0x00, //number defining this interface (IF we had more than one interface)       ==69
         0x00, //alternate setting                                                        ==70
         1, //number of endpoints for this interface                                      ==71
         0x03, //class code, 03 = HID                                                     ==72
         0x00, //subclass code //boot                                                     ==73
         0x00, //protocol code                                                            ==74
         0x00, //index of string descriptor for interface                                 ==75
   //class descriptor 2  (HID)
         USB_DESC_CLASS_LEN, //length of descriptor                                       ==76
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)                              ==77
         0x00,0x01, //hid class release number (1.0) (try 1.10)                           ==78,79
         0x00, //localized country code (0 = none)                                        ==80
         0x01, //number of hid class descrptors that follow (1)                           ==81
         USB_DESC_HIDREPORT_TYPE, //report descriptor type (0x22 == HID)                  ==82
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][0], 0x00, //length of report descriptor   ==83,84
   //endpoint descriptor 2
         USB_DESC_ENDPOINT_LEN, //length of descriptor                                    ==85
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)                      ==86
         USB_HID_JOY_IN_ENDPOINT | 0x80, //endpoint number and direction (0x81 = EP1 IN)                            ==87
         USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt)       ==88
         USB_EP3_TX_SIZE,0x00, //maximum packet size supported                            ==89,90
         2,  //polling interval, in ms.  (cant be smaller than 10 for slow speed devices) ==91
   //interface descriptor 3 (KEYBOARD)
         USB_DESC_INTERFACE_LEN, //length of descriptor                                   ==92
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)                   ==93
         0x01, //number defining this interface (IF we had more than one interface)       ==94
         0x00, //alternate setting                                                        ==95
         2, //number of endpoints for this interface                                      ==96
         0x03, //class code, 03 = HID                                                     ==97
         0x01, //subclass code //boot                                                     ==98
         0x01, //protocol code (keyboard)                                                 ==99
         0x00, //index of string descriptor for interface                                 ==100
   //class descriptor 3  (KEYBOARD)
         USB_DESC_CLASS_LEN, //length of descriptor                                       ==101
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)                              ==102
         0x00,0x01, //hid class release number (1.0) (try 1.10)                           ==103,104
         0x00, //localized country code (0 = none)                                        ==105
         0x01, //number of hid class descriptors that follow (1)                          ==106
         USB_DESC_HIDREPORT_TYPE, //report descriptor type (0x22 == HID)                  ==107
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][1], 0x00, //length of report descriptor   ==108,109
   //endpoint descriptor 3 IN
         USB_DESC_ENDPOINT_LEN, //length of descriptor                                    ==110
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)                      ==111
         USB_HID_KBD_IN_ENDPOINT | 0x80, //endpoint number and direction (0x81 = EP1 IN)  ==112
         USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt)       ==113
         USB_EP4_TX_SIZE,0x00, //maximum packet size supported                            ==114,115
         10,  //polling interval, in ms.  (cant be smaller than 10 for slow speed devices)==116
   //endpoint descriptor 3 OUT
         USB_DESC_ENDPOINT_LEN, //length of descriptor                                    ==117
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)                      ==118
         USB_HID_KBD_OUT_ENDPOINT, //endpoint number and direction (0x81 = EP1 IN)        ==119
         USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt)       ==120
         USB_EP4_RX_SIZE,0x00, //maximum packet size supported                            ==121,122
         10  //polling interval, in ms.  (cant be smaller than 10 for slow speed devices) ==123
   //****** BEGIN CONFIG DESCRIPTOR LOOKUP TABLES ********
   //since we can't make pointers to constants in certain pic16s, this is an offset table to find
   //  a specific descriptor in the above table.
   //NOTE: DO TO A LIMITATION OF THE CCS CODE, ALL HID INTERFACES MUST START AT 0 AND BE SEQUENTIAL
   //      FOR EXAMPLE, IF YOU HAVE 2 HID INTERFACES THEY MUST BE INTERFACE 0 AND INTERFACE 1
   #define USB_NUM_HID_INTERFACES   2
   //the maximum number of interfaces seen on any config
   //for example, if config 1 has 1 interface and config 2 has 2 interfaces you must define this as 2
   #define USB_MAX_NUM_INTERFACES   4
   //define how many interfaces there are per config.  [0] is the first config, etc.
   const char USB_NUM_INTERFACES[USB_NUM_CONFIGURATIONS]={4};
   //define where to find class descriptors
   //first dimension is the config number
   //second dimension specifies which interface
   //last dimension specifies which class in this interface to get, but most will only have 1 class per interface
   //if a class descriptor is not valid, set the value to 0xFFFF
   //Idx class in USB_CONFIG_DESC
   const int16 USB_CLASS_DESCRIPTORS[USB_NUM_CONFIGURATIONS][USB_MAX_NUM_INTERFACES][4]=
   //config 1
      //interface 0
         //class 1-4
         18,23,27,32,
      //interface 1
         //no classes for this interface
         0xFFFF,0xFFFF,0xFFFF,0xFFFF
      //interface 3
         76,0xFFFF,0xFFFF,0xFFFF
      //interface 4
         101,0xFFFF,0xFFFF,0xFFFF
   //****** END CONFIG DESCRIPTOR LOOKUP TABLES ********
   #if (sizeof(USB_CONFIG_DESC) != USB_TOTAL_CONFIG_LEN)
      #error USB_TOTAL_CONFIG_LEN not defined correctly
   #endif
///   start device descriptors
   const char USB_DEVICE_DESC[USB_DESC_DEVICE_LEN] ={
      //starts of with device configuration. only one possible
         USB_DESC_DEVICE_LEN, //the length of this report   ==0
         0x01, //the constant DEVICE (DEVICE 0x01)  ==1
         0x00,0x02, //usb version in bcd 2.0        ==3,4
         //0x10,0x01, //usb version in bcd  ==2,3
         0x00, //class code. 0x02=Communication Device Class ==4
         0x00, //protocol code ==6
         USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8) ==7
         0x61,0x04, //vendor id (0x04D8 is Microchip, or is it 0x0461 ??)  ==8,9
         0x55,0x00, //product id   ==10,11
         0x00,0x01, //device release number  ==12,13
         0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below)  ==14
         0x02, //index of string descriptor of the product  ==15
         0x00, //index of string descriptor of serial number  ==16
         USB_NUM_CONFIGURATIONS  //number of possible configurations  ==17
   #if (sizeof(USB_DEVICE_DESC) != USB_DESC_DEVICE_LEN)
      #error USB_DESC_DEVICE_LEN not defined correctly
   #endif
Do you have any idea what is wrong ?
Regards
NicolasC
PostPosted: Tue Aug 14, 2007 1:04 am     Reply with quote
I corrected a few errors in the above code and now the emuneration succeed.
I have now HID+KBD+CDC
I changed USB_CDC_COMM_XX_ENDPOINT accordantly.
When installing, I'm prompted for the CDC driver, but install fails.
HID+KBD are OK
I saw on the microchip forum
-Make sure the descriptor CDC readout is first (as number of EPs)
Is it linked to microchip library or to windows enum process ?
NicolasC
PostPosted: Thu Aug 16, 2007 3:28 pm     Reply with quote
It seems to related to the inf file:
'Can't find any information related to your hardaware ' (tanslated in english by me)
As CDC is now in a compound device, do I have to modify the inf file ?
PostPosted: Fri Aug 17, 2007 7:31 am     Reply with quote
Have you changed the PID or the VID? If so, yes.
NicolasC
PostPosted: Fri Aug 17, 2007 11:23 am     Reply with quote
Thanks for your answer because this now drives me crasy.
Yes I updated the PID and VIP.
I found in "Device Installation: Windows DDK" that composite device may need the following statement:
[DDInstall]
Include = AnotherINFFile.inf
Needs = AnotherINFFileDDInstall
[DDInstall.Services]
Needs = AnotherINFFileDDInstall.Services
but I still can't figure out how to use it. RTFM ?
PostPosted: Fri Aug 17, 2007 1:22 pm     Reply with quote
Hi´, I´m the same anonymous Smile
See if this helps you:
www (dot) osronline (dot) com/DDKx/buses/usbsystem_515z.htm
Please report back, i´m curious to know about a composite device made with a PIC working Smile
[DDInstall]
NicolasC
PostPosted: Fri Aug 17, 2007 4:18 pm     Reply with quote
I found a mistake I did when I update the inf file:
[CCS]
%CCS_CDC%=Reader, USB\VID_0461&PID_0055\MI_03
was wrong
[CCS]
%CCS_CDC%=Reader, USB\VID_0461&PID_0055&MI_03
load the driver. Smile but the interface refuse to start.
I ll keep you posted
Thanks again for the hint anonymous Smile
NicolasC
PostPosted: Sat Aug 25, 2007 8:17 am     Reply with quote
Hi
Here's the descriptor with all the errors (I founded) fixed.
The modified cdc_NTXP.inf file is accepted on enumeration but I have then the follwing error :
The device can't start (error 10)
Then I'm prompted again for a inf file, probably for the fourth interface : it seems that the control and the data interfaces are not read as a union.
Any hint ?
   //config 1
      //interface 0
         0,
      //interface 1
         31
   //config 1
      //interface 0
         31,
      //interface 1
         63
   #DEFINE USB_TOTAL_CONFIG_LEN      124 //config+interface+class+endpoint
      //    config(s)
      //    interface(s)
      //    class(es)
      //    endpoint(s)
   //interface descriptor 0 (HID)
         USB_DESC_INTERFACE_LEN, //length of descriptor                                   == 9
         1, //number of endpoints for this interface                                      ==13
         0x03, //class code, 03 = HID                                                     ==14
         0x00, //subclass code //boot                                                     ==15
         0x00, //protocol code                                                            ==16
   //class descriptor 0  (HID)
         USB_DESC_CLASS_LEN, //length of descriptor                                       ==18
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)                              ==19
         0x00,0x01, //hid class release number (1.0) (try 1.10)                           ==20,21
         0x00, //localized country code (0 = none)                                        ==22
         0x01, //number of hid class descrptors that follow (1)                           ==23
         USB_DESC_HIDREPORT_TYPE, //report descriptor type (0x22 == HID)                  ==24
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][0], 0x00, //length of report descriptor   ==25,26
   //endpoint descriptor 0
         USB_DESC_ENDPOINT_LEN, //length of descriptor                                    ==27
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)                      ==28
         USB_EP_JOY_IN_ENDPOINT | 0x80, //endpoint number and direction (0x81 = EP1 IN)  ==29
         USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt)       ==30
         USB_EP_JOY_TX_SIZE,0x00, //maximum packet size supported                         ==31,32
         2,  //polling interval, in ms.  (cant be smaller than 10 for slow speed devices) ==33
   //interface descriptor 1 (KEYBOARD)
         USB_DESC_INTERFACE_LEN, //length of descriptor                                   ==34
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)                   ==35
         0x01, //number defining this interface (IF we had more than one interface)       ==36
         0x00, //alternate setting                                                        ==37
         2, //number of endpoints for this interface                                      ==38
         0x03, //class code, 03 = HID                                                     ==39
         0x01, //subclass code //boot                                                     ==40
         0x01, //protocol code (keyboard)                                                 ==41
         0x00, //index of string descriptor for interface                                 ==42
   //class descriptor 1  (KEYBOARD)
         USB_DESC_CLASS_LEN, //length of descriptor                                       ==43
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)                              ==44
         0x00,0x01, //hid class release number (1.0) (try 1.10)                           ==45,46
         0x00, //localized country code (0 = none)                                        ==47
         0x01, //number of hid class descriptors that follow (1)                          ==48
         USB_DESC_HIDREPORT_TYPE, //report descriptor type (0x22 == HID)                  ==49
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][1], 0x00, //length of report descriptor   ==50,51
   //endpoint descriptor 1 IN
         USB_DESC_ENDPOINT_LEN, //length of descriptor                                    ==52
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)                      ==53
         USB_EP_KBD_IN_ENDPOINT | 0x80, //endpoint number and direction (0x81 = EP1 IN)   ==54
         USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt)       ==55
         USB_EP_KBD_TX_SIZE,0x00, //maximum packet size supported                         ==56,57
         10,  //polling interval, in ms.  (cant be smaller than 10 for slow speed devices)==58
   //endpoint descriptor 1 OUT
         USB_DESC_ENDPOINT_LEN, //length of descriptor                                    ==59
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)                      ==60
         USB_EP_KBD_OUT_ENDPOINT, //endpoint number and direction (0x81 = EP1 IN)         ==61
         USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt)       ==62
         USB_EP_KBD_RX_SIZE,0x00, //maximum packet size supported                         ==63,64
         10  //polling interval, in ms.  (cant be smaller than 10 for slow speed devices) ==65
   //interface descriptor 2 (comm class interface)
         USB_DESC_INTERFACE_LEN, //length of descriptor                                   ==66
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)                   ==67
         0x02, //number defining this interface (IF we had more than one interface)       ==68
         0x00, //alternate setting                                                        ==69
         1, //number of endpoints                                                         ==70
         0x02, //class code, 02 = Comm Interface Class                                    ==71
         0x02, //subclass code, 2 = Abstract                                              ==72
         0x01, //protocol code, 1 = v.25ter                                               ==73
         0x00, //index of string descriptor for interface                                 ==74
         5, //length of descriptor                                                        ==75
         0x24, //dscriptor type (0x24 == )                                                ==76
         0, //sub type (0=functional header)                                              ==77
         0x00,0x02, // cdc version                                                        ==78,79
         4, //length of descriptor                                                        ==80
         0x24, //dscriptor type (0x24 == )                                                ==81
         2, //sub type (2=ACM)                                                            ==82
         2, //capabilities        ==83  //we support Set_Line_Coding, Set_Control_Line_State, Get_Line_Coding, and the notification Serial_State.
         5, //length of descriptor                                                        ==84
         0x24, //dscriptor type (0x24 == )                                                ==85
         6, //sub type (6=union)                                                          ==86
         2, //master intf        ==87  //The interface number of the Communication or Data Class interface, designated as the master or controlling interface for the union.
         3, //save intf0        ==88  //Interface number of first slave or associated interface in the union. *
         5, //length of descriptor                                                        ==89
         0x24, //dscriptor type (0x24 == )                                                ==90
         1, //sub type (1=call mgmt)                                                      ==91
         0, //capabilities        ==92  //device does not handle call management itself
         3, //data interface                                                              ==93  //interface number of data class interface
         USB_DESC_ENDPOINT_LEN, //length of descriptor                                    ==94
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)                      ==95
         USB_CDC_COMM_IN_ENDPOINT | 0x80, //endpoint number and direction                 ==96
         0x03, //transfer type supported (0x03 is interrupt)                              ==97
         USB_CDC_COMM_IN_SIZE,0x00, //maximum packet size supported                       ==98,99
         250,  //polling interval, in ms.  (cant be smaller than 10)                      ==100
   //interface descriptor 3 (data class interface)
         USB_DESC_INTERFACE_LEN, //length of descriptor                                   ==101
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)                   ==102
         0x03, //number defining this interface (IF we had more than one interface)       ==103
         0x00, //alternate setting                                                        ==104
         2, //number of endpoints                                                         ==105
         0x0A, //class code, 0A = Data Interface Class                                    ==106
         0x00, //subclass code                                                            ==107
         0x00, //protocol code                                                            ==108
         0x00, //index of string descriptor for interface                                 ==109
         USB_CDC_DATA_OUT_ENDPOINT, //endpoint number and direction (0x02 = EP2 OUT)      ==112
         0x02, //transfer type supported (0x02 is bulk)                                   ==113
         USB_CDC_DATA_OUT_SIZE & 0xFF, (USB_CDC_DATA_OUT_SIZE >> 8) & 0xFF, //maximum packet size supported        ==114, 115
         250,  //polling interval, in ms.  (cant be smaller than 10)                      ==116
         USB_CDC_DATA_IN_ENDPOINT | 0x80, //endpoint number and direction (0x82 = EP2 IN) ==119
         0x02, //transfer type supported (0x02 is bulk)                                   ==120
         USB_CDC_DATA_IN_SIZE & 0xFF, (USB_CDC_DATA_IN_SIZE >> 8) & 0xFF, //maximum packet size supported          ==121, 122
         250,  //polling interval, in ms.  (cant be smaller than 10)                      ==123
   //config 1
      //interface 0
         //class 1-4
         18,0xFFFF,0xFFFF,0xFFFF
      //interface 1
         43,0xFFFF,0xFFFF,0xFFFF
      //interface 3
         75,80,84,89,
      //interface 4
   #endif
         USB_DESC_DEVICE_LEN, //the length of this report                                                 ==1
         0x01, //the constant DEVICE (DEVICE 0x01)                                                        ==2
         0x00, //class code        ==5
         0x00, //subclass code        ==6
         USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8)         ==8
         0x61,0x04, //vendor id (0x04D8 is Microchip, or is it 0x0461 ??)                                 ==9,10
         0x55,0x00, //product id        ==11,12
         0x00,0x01, //device release number                                                               ==13,14
         0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below)==15
         0x02, //index of string descriptor of the product                                                ==16
         0x00, //index of string descriptor of serial number                                              ==17
         USB_NUM_CONFIGURATIONS  //number of possible configurations                                      ==18
PostPosted: Mon Aug 27, 2007 5:22 am     Reply with quote
See if this hepls you
www (dot) cygna (dot) org/ubb/Forum9/HTML/001050.html
NicolasC
PostPosted: Mon Aug 27, 2007 5:55 am     Reply with quote
Thanks Guest
It seems to be what I need I 'll have a close look
PS: a letter was drop in the above post
http://www.cygnal.org/ubb/Forum9/HTML/001050.html
NicolasC
PostPosted: Tue Sep 04, 2007 2:57 am     Reply with quote
Hil all
Couldn't find anything to solve my problem but my descriptor seems to be ok. If so the trouble then must come from the modifications I made in CCS demo file in order to compile CDC and HID in the same project (ifdef CDC and ifdef HID where quite "exclusive").
Debugging this will not be easy :(
Regards
Nicolas
PostPosted: Tue Sep 04, 2007 4:01 am     Reply with quote
As a comment, have you got SP2 loaded on the (presumably XP) machine you are using to test?.
There were historical problems with usbser.sys, when it was used in a composite device. Have a look at the MS knowledgebase article 918365.
SP2, is meant to fix this.
NicolasC
PostPosted: Thu Sep 06, 2007 6:22 am     Reply with quote
I installed the hotfix. Things changed a bit: I'm prompted twice for driver for the 2 last interfaces ("Comm Interface Class" and "data class interface")
and 2 comport are added Mad . Then the device manager display a working icon for the first one. (Of course openning this com fails Sad )
I'm afraid this king of device support is broken under Windows : http://www.usb.org/phpbb/viewtopic.php?p=45645#45645
Nicolas
NicolasC
PostPosted: Wed Sep 12, 2007 3:09 am     Reply with quote
This kind of compound device is working using Microchip USB framework, but
that is incompatible with CCS USB library:
I couldn't found any workaround :(
PostPosted: Wed Sep 12, 2007 7:20 am     Reply with quote
What makes necessary to put CDC first? Windows, INF file or something else?
(the same Guest again... i think I should make an account Smile )
Goto page 1, 2  Next
Page 1 of 2
