MPLAB & CCS
MPLAB & CCS
PostPosted: Sat Sep 01, 2007 11:20 pm     Reply with quote
Can I write a function in mplab and use it in the CCS?
asmallri
PostPosted: Sun Sep 02, 2007 7:11 am     Reply with quote
MPLAB is an IDE. You can install CCS under MPLAB using the MPLAB environment to develop you CCS application. The source code is identical to that produced in the CCS IDE and is interchangable between the two development environments.
If you actually meant can you exchange between CCS C and Microchip C18 then you would need to "port" between the environments. This is not trivial.
Regards, Andrew
PostPosted: Sun Sep 02, 2007 7:30 am     Reply with quote
I think you don't understand my intention.
I want to write a function or macro with asm. and assemble it with MPASM
and use it in the C code.!!
Humberto
PostPosted: Sun Sep 02, 2007 9:58 am     Reply with quote
CCS User Manual
-> Open the folder PRE-PROCESSOR DIRECTIVES
--> Read the capabilities of #ASM directive.
This will give you the answer.
Humberto
