diehardfans
beginner help |
Posted: Thu Aug 30, 2007 8:05 pm |
i try to simulate the code below using A1 as input if the input of A1 is high the pin A2 will blink once if A1 input is low A3 will blink once
here is the code:
#include <16F84a.h>
#use delay (clock=4000000)
#fuses HS,NOWDT,NOPROTECT
#use rs232(baud=9600, xmit=PIN_A3, rcv=PIN_A2)
if ((input(PIN_A1)==1)
{output_high(PIN_A2);
delay_ms(50);
output_low(PIN_A2);
delay_ms(50);
output_high(PIN_A3);
delay_ms(50);
output_low(PIN_A3);
delay_ms(50);
i try to simulate using ISIS lite, but the only blink A3 no matter what input i insert...any idea what's happening ?
i insert the 16f84a, then i insert a logical input (0 or 1), then i run but the A2 condition never met ..why ?
[img]http://www.uploadimages.com/manage/MjM3NjQuMjU4MzI=
[/img]
[img]http://www.uploadimages.com/myalbum/23764[/img] |
Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
Posted: Fri Aug 31, 2007 6:21 am |
maybe because pin_a2 is taken by the #use rs232?
Ken |
SherpaDoug
Posted: Fri Aug 31, 2007 7:19 am |
Ken Johnson wrote: | maybe because pin_a2 is taken by the #use rs232?
Ken |
Since the commands for A2 follow the #use rs232 statement they should take control of the pin.
Diehardfans, you should learn touse the "code" button when posting code to this BBS to make reading your code easier.
I would just use if ((input(PIN_A1)) instead of if ((input(PIN_A1)==1).
I haven't used a simulator in many years, so I think it is a simulator problem ;-) I don't see anything wrong with your code. _________________ The search for better is endless. Instead simply find very good and get the job done. |
umka
Posted: Fri Aug 31, 2007 4:10 pm |
i ran this on my 16f84a and it worked. you were missing a ) after the if statment coz you had 3 ( and only 2)
i tried something else because it was behaving strangly, like work fine but then stick on one for a little bit then work fine agin but it didnt help.
Code: | #include <16F84a.h>
if ((input(PIN_A1)==1))
delay_ms(50);
output_low(PIN_A2);
delay_ms(50);
else if ((input(PIN_A1)==0))
delay_ms(50);
output_low(PIN_A3);
delay_ms(50);
diehardfans
Posted: Sun Sep 02, 2007 8:32 pm |
thanks for the viewing and the kindness of ur guys....
i will try again....
Keep it up... ![Laughing](images/smiles/icon_lol.gif) |
