#if defined s
#define sht11_data PIN_A0
#define sht11_sck PIN_A1
#elif defined !s
#define sht11_data PIN_A2
#define sht11_sck PIN_A3
How can I use two sensor (SHT11) with same driver ?? I wrote that , But It read only one of them :( Please HELLPPPPPP
Not :S int1 variable
SherpaDoug
Posted: Wed Aug 29, 2007 7:42 am
I am not sure this is valid
#elif defined !s
I would use S1 and S2 instead of S and !S. _________________ The search for better is endless. Instead simply find very good and get the job done.
Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
Posted: Wed Aug 29, 2007 9:45 am
Why not:
#if defined s
#else
or
if !defined s
etc . . .
Ken
Posted: Wed Aug 29, 2007 10:11 am
IT did not work so. How I can write else
SherpaDoug
Posted: Wed Aug 29, 2007 11:32 am
You will have to tell us HOW it didn't work. Did it compile? What did it do or not do? _________________ The search for better is endless. Instead simply find very good and get the job done.
