Unstable serial comm when using internal osc?
dave4
PostPosted: Tue Aug 28, 2007 12:23 am     Reply with quote
I'm using an internal osc and the serial comm is unstable. Sometime the data is good and sometime it is garbled. Can anyone relate this or I am doing something wrong?
RossJ
PostPosted: Tue Aug 28, 2007 12:57 am     Reply with quote
Which PIC are you using?
Are you working at room temperature (i.e. 25C)?
Are you autonegotiating the baud rate or is this fixed (at both ends)?
Most PIC18s have a factory calibrated INTOSC which is typically accurate to +/-1% at 25C. The INRC oscillator is very inaccurate and can be +/-10% or more and is NOT appropriate for baud rate generation.
USART comms should be reliable with baud rate errors of a couple of percent. Serial comms using the USART is timing critical since there is no separate clock (as is the case with say I2C). So clock error/drift could well be responsible for data errors.
If you suspect clock/baud rate accuracy problems, test the clock's accuracy. Either use an oscilloscop or some other suitable test instrument, or write a routine to output a fixed length pulse on an IO (say 60 seconds) and time it with a stop watch.
SET
PostPosted: Tue Aug 28, 2007 8:47 am     Reply with quote
The INTOSC is pretty stable and good enough for UART clocking - we had one project where we were running at a non-standard Baud rate (was around 230kBaud), and the fixed error between both sides was around 3% - and with this we never lost data. So with standard Baud rates if you get within 2% it should be fine.
Ken Johnson
PostPosted: Tue Aug 28, 2007 9:12 am     Reply with quote
Using the internal osc on a 485 network caused me problems. The baud rate was ok, but, using a master-query where each slave would respond in a time slot, based on an id, sometimes failed. My time slots were too close together, and by the time id #25 reported, it might crash over top of #24 or #26. Doesn't sound like this is your problem, but thought I'd throw it in just in case Smile
Ken
Douglas Kennedy
PostPosted: Tue Aug 28, 2007 2:15 pm     Reply with quote
Its a long shot and it depends on the chip you are using ...but could it be you overwrote the internal rom location that stores the calibration constant
Ex for 12F629
#rom 0x3FF = {0x3490}
//// sets the internal oscillator to mid freq (0x3480) (0x34B0) near 4mhz
//// 0x3FF is top of rom and must contain a retlw instruction
//// with the value for the internal osc calibration
/// retlw is 0x34kk so kk Ex 80 is the value placed in OSCAL
/// osccal is xxxx xx.. max 1111 11.. mid 1000 00.. min 0000 00..
/// 0xFC 0x80 0x00
/// if the location 0x3FF is erased in error the osc won't run
/// freq affects baud rate one 629 needs 3470 the other 34B0
dave4
PostPosted: Tue Aug 28, 2007 3:19 pm     Reply with quote
i'm using PIC12F683
dave4
PostPosted: Tue Aug 28, 2007 3:40 pm     Reply with quote
Here is my code
#include <12F683>
#fuses INTRC, NOWDT, NOPROTECT, NOBROWNOUT, NOMCLR
#use delay(clock = 8000000)
main()
setup_oscillator(OSC_8MHZ|OSC_NORMAL);
      output_high(PIN_A5);
      output_low(PIN_A5);
I'm confused whether this is setup is for internal RC or internal OSC.
PostPosted: Tue Aug 28, 2007 3:41 pm     Reply with quote
dave4 wrote:
Here is my code
#include <12F683>
main()
      output_low(PIN_A5);
And also, I measured the frequency at the IO pin (clk output) and it measured only 2mhz. Maybe I don't understand the purpose of this pin but isn't it suppose to also be 8mhz?
PostPosted: Tue Aug 28, 2007 5:34 pm     Reply with quote
Anonymous wrote:
dave4 wrote:
Here is my code
#include <12F683>
main()
      output_low(PIN_A5);
All questions answered.
Thanks.
SherpaDoug
PostPosted: Wed Aug 29, 2007 7:39 am     Reply with quote
If you look at the 12F683 datasheet figures 16-38,16-39,16-40 you will see that the HFINTOSC can easily drift over 3% with changes of voltage and temperature. I have seen desktop PCs that were off by almost 2% sitting on my desk. Using a software UART sometimes if 9600 baud doesn't work I try 9408 baud or 9792 baud (9600 +/- 2%) to see if it works better.
