pokiko
Need help on pwm |
Posted: Wed Aug 22, 2007 8:10 am |
i am using pic18f2520 with 20mhz osc and i have to write a program which will drive a full bridge thyristor. The client will enter a set voltage. By triggering the thyristors with suitable pwm, i will force the output to the desired voltage. I am using version 3.212.
The pin configuraion is as follows(This is not code):
pic_pins pic pins used as:
RA0..RA5 //to LEDS(not so important)
RC0 SW1
RC1 PWM2
RC2 PW1
RC3 SW2
RC4 SW3
RC5 SW4
RC6 --
RC7 --
RB0 Vout //analog feedback input for voltage
RB1 Iout //and current
RB2 RS // pins to LCD
RB3 E //
RB4 D4 //
RB5 D5 //
RB6 D6 //
RB7 D7
When i compile it, an error occurs such as "A numeric expression must appear here ". I want to know if a pwm selection, (such below main() ), would be a good approach or would it be better to match a specific voltage value to a specific pwm? Are there any other mistakes? If yes can you help me how can i correct them?
#include <18F2520.h>
#device adc=8
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#include "Flex_LCD.c"
#define BUTON_UP PIN_C0
#define BUTON_DOWN PIN_C3
#define BUTON_ENTER PIN_C4
#define BUTON_BREAK PIN_C5
/*----------GLOBAL VARIABLES-----------*/
int8 duty_value;
int16 adc_value;
float count_adc, LCD_voltage, Error;
//--------- LCD MENU ----------------//
#INT_EXT
float ext_isr(float volt,float amper)
volt=0;
volt_set: lcd_putc("\f");
lcd_gotoxy(1,1);
printf(lcd_putc,"volt set");
lcd_gotoxy(1,1);
lcd_putc("\fvolt +");
lcd_gotoxy(1,2);
lcd_putc("volt -");
lcd_gotoxy(1,1);
printf(lcd_putc, "\f%3.2f", volt);
if (input(BUTON_UP))
volt+=0.2;
if(volt>30)
volt=30;
printf(lcd_putc, "\fvolt=%3.2f", volt);
if (input(BUTON_DOWN))
volt-=0.2;
if(volt<0)
volt=0;
if (input(BUTON_ENTER))
return volt;
goto volt_set;
/* ---------------- MAIN PROGRAM -------------------*/
int init_ADC(void);
//float LCD_menu(float volt,float amper);
int init_ADC(void)
setup_adc_ports( ALL_ANALOG );
setup_adc( ADC_CLOCK_DIV_2 );
set_adc_channel( 12 ); //Sets A_to_D input to channel 12
set_adc_channel(10);
delay_us(10);
set_tris_a(0b00000100);
set_tris_b(0b00000011);
set_tris_c(0b00111001);
delay_ms(10);
output_low(PIN_C2); // Set CCP1 output low
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
output_low(PIN_C1); // Setup CCP2 output low
setup_ccp2(CCP_PWM); // Configure CCP2 as a PWM
setup_timer_2(T2_DIV_BY_1,255,1);
pwm_calibration: adc_value = read_ADC();
delay_us(10);
count_adc=((float)(adc_value/1023))*30;
LCD_voltage=ext_isr();
Error=LCD_voltage-count_adc;
if(Error>0.2)
++duty_value;
if(duty_value>254)
duty_value=254;
set_pwm1_duty(duty_value);
set_pwm2_duty(duty_value);
printf(lcd_putc,"\fvolt=%3.2f",voltage);
goto pwm_kalibration;
if(Error<-0.2)
{--duty_value;
if(duty_value<1)
duty_value=1;
printf(lcd_putc,"\fvolt=%3.2",voltage);
if (Error<0.2 & Error>-0.2)
goto pwm_calibration;
Posted: Wed Aug 22, 2007 10:02 am |
An ISR, _never_ accepts a value, or returns a value. It must be declared as void (it makes no sense to have it accepting or returning a value, since you do not know _when_ it is going to occur in the main code, and there is nothing 'calling' it, to give it a value, or to have a value returned)...
Then you have 'init_ADC' declared to return an int, but returning nothing.
This routine, is then declared 'inside' main. This is not legal.
You declare an ISR, but never enable the interrupt.
