franckcl
Joined: 12 Sep 2003 Posts: 32 Location: France (Paris)
set_pwm1_duty : range of the parameter ? |
Posted: Mon Aug 20, 2007 7:20 am |
I have a question about the use of the funcion set_pwm1_duty(int value).
What is the range of the value passed into parameter ?
I have tried that :
unsigned char b;
b=101;
set_pwm1_duty(b);
So for exactly 101, the output is at the maximum !
Why ? it is a 8 bit value so I should have the maximum for 255 ?
(I have tried using a 16 bits variable, and the maximum is for obtained at 404)
Thank you
franck |
Posted: Mon Aug 20, 2007 7:24 am |
The range, depends on what timer2 is set to.
If you setup timer2, with:
setup_timer_2(T2_DIV_BY_1,100,1);
Then the maximum width that can be used is 100. If you chose:
setup_timer_2(T2_DIV_BY_1,255,1);
The output frequency will be just 1/2.55 of the former example, but the count can go to 255.
Posted: Mon Aug 20, 2007 7:30 am |
Thank you very much for this fast answer Ttelmah !
My timer is set to : setup_timer_2(T2_DIV_BY_16,100,13);
So I anderstand now !
Thank you again, you are a champion !
franck |
