interrupts
irt11
interrupts
PostPosted: Sat Aug 18, 2007 7:41 am     Reply with quote
Interrupts disabled during call to prevent re-entrancy: (disp_comm2)
can anyone provide further detail on the above warning message?
I assume it means that any interrupt that could call disp_comm2 is disabled while in disp_comm2. The thing is I don't have any interrupt routines that call disp_comm2. So, I'm confused by this.
Any help would be greatly appreciated
Ken Johnson
PostPosted: Sat Aug 18, 2007 8:05 am     Reply with quote
disp_comm2 probably calls something that is also called from you main loop. Maybe even a library routine. General rule - keep your isr short, doing no more than necessary - set a flag and do the rest in the main loop.
Hope this helps,
Ken
