BrunoCF
Thanks |
Posted: Tue Aug 14, 2007 5:00 am |
Thank you for the code. Worked just fine for me. |
nmeyer
Posted: Fri Aug 17, 2007 8:38 am |
I have purchased the PICDEM 2 PLus board and i am using the Flex_lcd driver for the lcd. However, i am finding that if i try to write more than 7 characters on a line, it locks up the PIC.
#include <18F4520.h>
#device adc=8
#include <stdio.h>
#include <math.h>
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#use delay(clock=4000000,RESTART_WDT)
#include <Flex_LCD>
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
while (true)
output_low(PIN_B0);
output_low(PIN_B1);
output_low(PIN_B2);
output_low(PIN_B3);
output_low(PIN_C2);
output_high(PIN_B0);
output_high(PIN_B1);
output_high(PIN_B2);
output_high(PIN_B3);
//output_high(PIN_C2);
printf("Hello\n\r");
output_high(PIN_D7);
lcd_init();
printf(lcd_putc,"\fRawson\n");
printf(lcd_putc,"Accurat");
Does anyone have any idea what i am doing wrong? |
Posted: Fri Aug 17, 2007 9:07 am |
Quote: | #FUSES XINST //Extended set extension |
This fuse setting will cause the program to run erratically.
Change it to NOXINST. Do this in all your programs for PICs that
have that fuse. |
nmeyer
Posted: Fri Aug 17, 2007 12:12 pm |
Thanks for the input. Do you have any ideas on why i can only do 7 characters? |
Posted: Fri Aug 17, 2007 12:40 pm |
1. The 'XINST' fuse could be the cause of it doing only seven characters.
Make sure you change it to 'NOXINST' in all your programs.
It's essential.
2. Post the list of #define statements that show the connections
between the LCD and the PIC. These #define statements are at
the start of the Flex_lcd.c driver, and must match the connections
on your PIC board.
3. Your test program is too complicated. Try a very simple program.
Example:
#include <18F4520.H>
#use delay(clock = 4000000)
#include "flex_lcd.c"
lcd_init();
lcd_putc("\fHello World\n");
lcd_putc("Line Number 2");
nmeyer
Posted: Fri Aug 17, 2007 3:17 pm |
I changed the setting to NOXINST and it still performed the same. Here are my defines from the flex_lcd file.
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver. Change these
// pins to fit your own board.
#define LCD_DB4 PIN_D0
#define LCD_DB5 PIN_D1
#define LCD_DB6 PIN_D2
#define LCD_DB7 PIN_D3
#define LCD_E PIN_D6
#define LCD_RS PIN_D4
#define LCD_RW PIN_D5
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
#define USE_LCD_RW 1
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line |
Posted: Fri Aug 17, 2007 3:52 pm |
Based on those pin numbers, you are apparently using the new "Rohs
update" version of the PicDem2-Plus board.
That version of the board can be identified by a surface-mount pad
pattern at the bottom of the proto-typing area on the board. The older
version of the board doesn't have that surface-mount area on it.
If you have the new Rohs version of the board you need to use the
test program shown below. Notice how it adds a #define statement
for the LCD power pin, and it adds two new lines at the start of main().
Those lines are essential for the new Rohs version of the PicDem2-Plus.
Here are the pin assignments that you must set at the top of the Flex
driver. Also, for the "Rohs" PicDem2-Plus board, you must comment
out the "#define USE_LCD_RW 1" line, as shown below.
// These are the pin assignments used for the "Rohs"
// PicDem2-Plus:
// The following line must be commented out for
// the "Rohs" board.
// #define USE_LCD_RW 1
Test program for "Rohs" version of PicDem2-Plus board:
#define LCD_POWER PIN_D7
#include "Flex_LCD.c"
output_high(LCD_POWER); // Turn on power to LCD
output_low(LCD_RW); // Set R/W pin on LCD to a low level
lcd_init(); // Initialize the LCD
nmeyer
Posted: Tue Aug 21, 2007 11:20 am |
These changes seem to be working well.
Thanks |
d
Posted: Thu Sep 06, 2007 8:32 am |
thanks for the code
works perfect, first time!
d. |
syahrul.s
Posted: Fri Nov 09, 2007 2:14 am |
can the flex_lcd.c be used with LCD-016M002B by Vishay?? |
Posted: Fri Nov 09, 2007 11:21 am |
The Vishay LCD has a KS0066 controller, which is compatible with
the HD44780. So it should work OK with the Flex driver. |
Praad
Posted: Thu May 15, 2008 10:42 am |
[ sorry for my bad english I'm .fr ;p ]
Great work PCMProgrammer.
I've just tested lcd_flex on my PIC16F876 with a 2x16 LCD : gdm1602a
I changed pins etc. With Proteus ISIS all is ok, however when I test the program on the real pic & lcd it doesn't works. It print black squares (is it the good word ?).
Why ? :s
http://elmicro.com/files/lcd/gdm1602a_datasheet.pdf
thx |
Posted: Thu May 15, 2008 12:25 pm |
The LCD displays black squares when:
1. The LCD is not initialized.
or
2. The contrast voltage is not correct.
So, to fix this:
1. Make sure you call the lcd_init() function at the start of main().
Also make sure the connections to the LCD are correct.
The data pins on the LCD must be DB4-DB7 (do not use DB0-DB3).
2. Set the contrast voltage to 0.5 volts. Use a voltage divider or
a trimpot to get this voltage. The contrast pin is called "Vo" in the
LCD data sheet. It's on pin 3 of the LCD. |
Praad
Posted: Thu May 15, 2008 12:49 pm |
I use DB4-DB7 data pins on the LCD.
For the contrast voltage I use a poteniometer (RVLCD) :
But with all these things the LCD displays black squares
I tried this morning (at school) to make it works but without success.
Thx |
Posted: Thu May 15, 2008 12:57 pm |
In your schematic, you have the R/W pin connected to ground.
With that connection, you must "comment out" the following line
in the Flex LCD driver. Do this by adding comment symbols in
front of the line. Example:
Quote: | // #define USE_LCD_RW 1 |
Then re-compile and test it. |
