A6280 help
sagamenn
A6280 help
PostPosted: Thu Aug 16, 2007 8:32 am     Reply with quote
CCS A6280 c code help me!
thank you
sagamenn
Re: A6280 yardım
PostPosted: Fri Aug 17, 2007 12:32 am     Reply with quote
thank you
http://www.allegromicro.com/en/Products/Part_Numbers/6280/6280.pd
PostPosted: Fri Aug 17, 2007 12:33 am     Reply with quote
My advice is to use http://www.google.com with this search string:
"led driver" "#use delay" "fuses"
This will find CCS code. Then compare the data sheets for the
led drivers that are used in the code that you find, to the data
sheet for your led driver chip. They will probably be similar,
which means you can use the code.
Another option is to go to the Allegro website. Get the data sheet
for your led driver. Compare it to other led driver data sheets.
Find a commonly used led driver that has the same architecture
as your chip does. Then use Google to search for a driver for
that chip.
A third option is to just use an led driver that isn't so new.
Use a compatible one, that already has several drivers available
for it on the net.
A final option is to write your own driver.
sagamenn
PostPosted: Fri Aug 17, 2007 2:01 am     Reply with quote
ı dont find abaout A6280 DEMO CODE in google...can you help about this ...or give me a some example of allegro A6280 ..please...
kevcon
PostPosted: Fri Aug 17, 2007 7:07 am     Reply with quote
This looks like a pretty cool part.
This is basically a big shift register, I'm sure there is code out there somewhere shows how to control a shift register.
treitmey
PostPosted: Fri Aug 17, 2007 7:44 am     Reply with quote
Yup, its the 74595.c and 74165.c as output and input respectively.
I use the TPIC6C595 to drive relays and LEDs.
http://rocky.digikey.com/WebLib/Texas%20Instruments/Web%20data/tpic6c595.pdf
