PIC connection to PC
Julia
PostPosted: Thu Aug 09, 2007 12:44 pm     Reply with quote
I need to do a connection PIC-PC (USB maybe?) to send just 1 bytes to the PC without locking the CPU. I'm kind of a newbie , so please if there's someone that could help if some examples to start.
PostPosted: Thu Aug 09, 2007 4:05 pm     Reply with quote
RS-232 connection (not USB) to PIC:
http://www.ccsinfo.com/forum/viewtopic.php?t=26898
Julia
PostPosted: Tue Aug 14, 2007 6:38 pm     Reply with quote
It worked the connetion PIC-hyperTerminal , but I need to use the information the PIC sent to me for another program I developed in my PC. Do you have any references about how to do this? How to program using the hyper-Terminal information.
Thank you very much for your help
Julia
Steve H.
PostPosted: Tue Aug 14, 2007 8:07 pm     Reply with quote
Parallax has many application notes on how to do serial data links - They are in Pic Basic, but it is easy to convert to PIC C - the idea of how this works is what you are looking for, yes?
check them out at: parallax.com/
Then check out the RS232 extensions for the PIC C compiler (in the manual). You will find PIC C to be very easy.
HTH - Steve H.
