_Return_ gives a compiler warning
heath.g
PostPosted: Sun Aug 12, 2007 6:26 pm     Reply with quote
Under version 3 you could do this and it wouldnt return warning:
int8 ReturnTest(void)
#asm
      movlw    0x01
      movwf   _RETURN_
#endasm
Does anyone know how to stop the warning appearing. It doesnt effect the code, I just dont like warnings if the code is unaffected as the function works.
Warning is: Function not void and does not return a value ReturnTest
Thanks.
PostPosted: Sun Aug 12, 2007 6:55 pm     Reply with quote
Add this line after your pre-processor statements.
#ignore_warnings 208
Neutone
Re: _Return_ gives a compiler warning
PostPosted: Mon Aug 13, 2007 11:43 am     Reply with quote
#asm
      movlw    0x01
      movwf   _RETURN_
#endasm
Thanks.
You could try this as well.
return (1);
heath.g
PostPosted: Mon Aug 20, 2007 12:13 am     Reply with quote
Thanks for that, I will use this.
