CCS names for Fuses
Ed_Bennett
CCS names for Fuses
PostPosted: Sun Aug 12, 2007 8:32 pm     Reply with quote
These are for the '690, but they cover a few more chips. It was fun ferreting out the functions of the fuses/configuration bits. Additions and corrections are requested!
"FUSES" (CCS names)
OSCILLATOR
HS              high speed clock (external xtal)
XT              medium gain crystal or ceramic resonator
INTRC           8 MHZ Internal RC clock
                    OSC1=Gen Purpose I/O, OSC2=Fosc/4
INTRC_IO        8 MHZ Internal RC clock
                    OSC1 and OSC2 pins are normal I/O
LP              low power 32kHz crystal
EC              external clock with I/O on OSC2
EC_IO           same as EC_IO (?)
RC              external RC clock with Fosc/4 on OSC2
RC_IO           external RC clock with I/O on OSC2
FCMEN           failsafe clock monitor enabled
NOFCMEN         no FCMEN
IESO            Internal External Switchover
NOIESO
                Switchover means two-speed clock startup:
                1024 cycles at low speed, then go to external
                oscillator for high speed
SECURITY
PROTECT         turn on code protect -
                    blocks reading of the MCU program
NOPROTECT       no code protect
CPD             data eeprom protect -
                    only cpu can access eeprom
NOCPD           no CPD protection
RESET
WDT             activate watchdog timer
NOWDT           no watchdog timer
BROWNOUT        enable brownout protection
NOBROWNOUT      no brownout protection
BROWNOUT_SW     enable software control (?) of brownout
BROWNOUT_NOSL   disable brownout sensing during sleep
PUT             power up timer enabled
NOPUT           power up timer disabled
--> PUT is enabled by default when BROWNOUT is enabled
MCLR            enable master clear (reset pin)
NOMCLR          reset pin is normal I/O (input ONLY)
PostPosted: Mon Aug 13, 2007 1:37 am     Reply with quote
A (short) description of all CCS fuse names can be found in C:\Program Files\PICC\fuses.txt
Ed_Bennett
CCS names for Fuses
PostPosted: Mon Aug 13, 2007 1:50 am     Reply with quote
That must be a version 4 thing. Good for CCS. I'm using 3.249.
-e
PostPosted: Mon Aug 13, 2007 2:12 am     Reply with quote
No. It is there even in the old 3.1xx compiler versions. Change 'PICC' for the directory where your compiler is installed, if you didn't use the defaults...
PostPosted: Mon Aug 13, 2007 11:11 am     Reply with quote
The fuses.txt file only comes with the full IDE. You don't get it with
the command line compilers.
PostPosted: Mon Aug 13, 2007 3:39 pm     Reply with quote
However, there is still a way to get it. It's included in the CCS demo.
http://www.ccsinfo.com/faq.php?page=compiler_demo
After installing it, the fuses.txt file is in this directory:
c:\Program Files\Picc
If you have the command line compiler, I would advise installing the
demo on a different PC, so it doesn't interfere with your existing compiler
installation. Even if you install it in a different directory, when you
un-install it, it can delete your crg files for your command line compiler.
See my post in this thread about this:
http://www.ccsinfo.com/forum/viewtopic.php?t=23835&highlight=crg+files+deletes
Installing the demo on a different PC eliminates this problem.
