Peter Guest
#int_ext and, inline and "Different Levels of Indirecti |
Posted: Sat Aug 11, 2007 5:07 pm |
Hello there.
I'm fooling around PIC16F684 and when trying to implement the interrupt #int_ext , compiler says about different levels of indirection.
Let's say the code looks as follows:
void doSth(int& data)
data= ...... ;
#int_ext
void myfunc1(void)
int i;
for (i=4; i--;)
doSth(dataOne[i], 8); // <== different levels of indirection!!!
I also have noticed that doSth is treated by CCS compiler like an inline function (just in scope of myFunc1). This is - I guess - the source of the issue. How to overcome this? I could give up on this loop and call doSth 4 times, but it takes each time a huge chunk of the program memory that I'm getting short of!
Cheers,
Peter. |
Peter Guest
Posted: Sat Aug 11, 2007 6:06 pm |
Just forgotten, when passing pointer rather than a reference, the same thing happens! So the following doesn't work:
void doSth(int* pdata, int secondpar)
*pdata= ...... ;
Peter Guest
Posted: Sat Aug 11, 2007 6:13 pm |
Right, false alarm! Sorry. Checked this code once more and this was owing to a reference parameter as expected!
Cheers,
Peter. |
