RS232 transmits data incorrectly. Why?
stefan_d6
PostPosted: Thu Aug 09, 2007 5:25 am     Reply with quote
This subject is often discused here but I couldn't find solution to my problem.
I use the following code to get info from PIC18F1320 according to the sent command from PC. If the command word is 'nXXXX' - the PIC sends to the PC the timer0 counts. If the command word is 'd+[0000 to 1024]' - the PC sets the PWM duty cycle.
The problem is that the PC sends randomly commands like [d,,,ю] or something like that, i.e. the data is transmitted incorrectly. I checked the levels of the according pins of MAX232 - they are +8.5/-8.5 V - are these levels correct. Where to look for the problem?
#include <18F1320.h>
#use rs232(baud=9600, xmit=PIN_B1, rcv=PIN_B4,ERRORS)
// constants and vars used for commport communications:
#define R_BUFFER_SIZE 32
byte r_buffer[R_BUFFER_SIZE];
byte r_next_in = 0;
byte r_next_out = 0;
#include <stdlib.h>
#INT_RDA
void r_serial_isr() {
   int t;
   r_buffer[r_next_in] = getc();
   t = r_next_in;
   r_next_in = (r_next_in + 1) % R_BUFFER_SIZE;
   if(r_next_in == r_next_out)
   r_next_in = t;           // Buffer full !!
   delay_us(10);
#define bkbhit (r_next_in != r_next_out)
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c = r_buffer[r_next_out];
   r_next_out = (r_next_out + 1) % R_BUFFER_SIZE;
   putc(c);
   return(c);
   float rps,rpm;
   long turns,duty;
   char cmd;
   char s[4];
   printf("\r\n ==== Test program - 22.07.2007 ====\r\n");
   setup_ccp1(CCP_PWM);
   setup_timer_2(T2_DIV_BY_1, 255, 1);  //The cycle time will be (1/clock)*4*t2div*(period+1)
                                        // tcycle = (1/20000000)*4*1*256 = 51.2us  ->  19.53125kHz
   set_pwm1_duty(0);                    // duty = tcycle*clock/t2div
                                        // 20% -> 10.24us x 20MHz = 204.8 ~205
                                        // 50% -> 25.6 x 20 = 512
   setup_timer_0(RTCC_EXT_L_TO_H);
   enable_interrupts(int_rda);
   enable_interrupts(global);
   while(true)
      cmd =bgetc();
      s[0]=bgetc();
      s[1]=bgetc();
      s[2]=bgetc();
      s[3]=bgetc();
      switch(cmd){
      case 'n':delay_ms(1000);
               turns=get_timer0();
               rps=(float)turns/36;
               rpm=rps*60;
               printf("%6.3f",rpm);
               set_timer0(0);
      case 'd':duty=atol(s);
               set_pwm1_duty(duty);
               printf("\r\nduty = %Lu \r\n", duty);
      default :printf("\r\nError\r\n");
               break;}
inservi
PostPosted: Thu Aug 09, 2007 6:00 am     Reply with quote
I think it is a problem in bgetc(). you send a byte at the same time that bytes are probably received. The send is interupted by the #INT_RDA and the timing can not be good.
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
-->putc(c);
   return(c);
dro.
in médio virtus
SET
PostPosted: Thu Aug 09, 2007 9:30 am     Reply with quote
No this should be Ok if the hardware UART is being used.
SET
PostPosted: Thu Aug 09, 2007 9:35 am     Reply with quote
#INT_RDA
   int t;
   t = r_next_in;
   delay_us(10);
You dont need the 10us delay.
Is your PC adding CR or LF by any chance? Then your parser will get out of sync.
PostPosted: Thu Aug 09, 2007 9:42 am     Reply with quote
First comment. Get rid of the delay in the RDA interrupt. This is stupid, not needed, and _will_ cause problems (since delays are used in the 'main', interrupts will be disabled dring these...).
Second comment. Consider buffering the serial output as well. EX_STISR shows how to do this. The problem is that some of your 'reply' messages are long (potentially 16 characters for the worst case on the duty cycle reply), and for the whole of this time, the code cannot process data from the incoming buffer. If the message rate is reasonably high, this could lead to a buffer overflow...
inservi
PostPosted: Thu Aug 09, 2007 11:19 am     Reply with quote
Sorry, i not realized that the send use the hardware UART to.
dro.
in médio virtus
stefan_d6
PostPosted: Wed Aug 22, 2007 6:26 am     Reply with quote
I finally solved the problem.
I just changed the baud rate to 19 200 and rs232 works without errors. However I didn't find out way rs232 didn't work correctly with 9600 baud rate. I also removed int_rda and instead I use kbhit() - I think my code allows such construction without any loss of data. Am I right?
#use rs232(baud=19200, xmit=PIN_B1, rcv=PIN_B4,ERRORS)
#include <stdlib.h>
#include <input.c>
   float rps,rpm;
   long turns,duty;
   char cmd,no;
   printf("--- Test program ---");
   while(true)
      if(kbhit())
         cmd =getc();
         switch(cmd)
         case 'n':set_timer0(0);
                  no=getc();
                  turns=get_timer0();
                  rpm=rps*60;
                  printf("\r\n%6.3f",rpm);
         case 'd':duty=get_long();
                  printf("\r\nduty = %Lu",duty);
         default :printf("\r\nError");
Douglas Kennedy
PostPosted: Wed Aug 22, 2007 9:17 am     Reply with quote
You should take a long look at Ttelmahs advice. Very very often the only way to get absolutely reliable RS232 reception is with a very short interrupt service routine that feeds a circular buffer. There must be now be dozens of issues with RS232 almost all were solved with the circular buffer approach. It's not that you can't find another way it is just not likely to work as well as Ttelmahs advice.
