Help to generated square wave!
blinkstar88
PostPosted: Wed Aug 08, 2007 8:40 am     Reply with quote
Hi i'm new on CCS, i need to generated multiple square wave (38Khz,76KHz, 304Khz,19Khz) on portB using 4.864Mhz crystal. I get the following code from Example of CCS:
But i don't know to change the code for this freq. Please help.
Any idea and help very aprreciated
#if defined(__PCM__)
#include <16F628a.h>
#use delay(clock=4864000)
#elif defined(__PCH__)
#include <18F452.h>
#endif
#define NUM_OUTPUTS 8
//NOTE: periods MUST be multiples of 400
//Periods are in microseconds
#define PERIOD_0 400
#define PERIOD_1 800
#define PERIOD_2 1600
#define PERIOD_3 2000
#define PERIOD_4 20000
#define PERIOD_5 64000
#define PERIOD_6 2000000
#define PERIOD_7 2800000
const long wave_period[NUM_OUTPUTS] = {
PERIOD_0/400, PERIOD_1/400, PERIOD_2/400, PERIOD_3/400,
PERIOD_4/400, PERIOD_5/400, PERIOD_6/400,PERIOD_7/400};
long counter[NUM_OUTPUTS] = {0,0,0,0,0,0,0,0};
int port_b_image;
// This interrupt is used to output the waveforms. The interrupt
// is automatically called ever 200us.
#INT_TIMER1
void wave_timer() {
int i;
set_timer1(0xFC4F); // sets timer to interrupt in 200us
output_b(port_b_image); // outputs the waveform
for(i=0; i<NUM_OUTPUTS; i++) // sets up next output for each pin
if((++counter[i]) == wave_period[i]) // if counter is expired
counter[i] = 0; // reset counter
if(bit_test(port_b_image,i)) // and set pin as needed
bit_clear(port_b_image,i);
bit_set(port_b_image,i);
void main() {
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); // setup interrupts
port_b_image=0; // initialize variable
while(TRUE); // loop forever
SherpaDoug
PostPosted: Wed Aug 08, 2007 9:19 am     Reply with quote
That code only generates up to 25kHz square waves. You might be able to squeeze out 38kHz, but I don't think 76kHz and 304kHz with only a 4.86MHz crystal can be done. You can get some more speed with a faster crystal but 304kHz is going to be hard. You will have to poll timers rather than using interrupts.
Years ago I did a synthesizer (numerically controlled oscillator) that did 32kHz or maybe 35kHz on a PIC16C54 running at 20MHz but it was tough.
If you can make do with even power of 2 divisions of the clock frequency (303.75kHz etc.) it will be easier. Read the PIC datasheet section about timers to get a feel for what can be done.
blinkstar88
PostPosted: Wed Aug 08, 2007 11:20 am     Reply with quote
SherpaDoug, Thank for the replay.
I want to use this code for FM Encoder stereo from Broadcast Warehouse, they design using crystal 4.864Mhz and Pic16c620. They generated 8 freq in realtime (PortB pin0 = 38Khz, Portb Pin 1 = 114 Khz, Portb Pin 2 = 114Khz, Portb Pin 3 = 38Khz) and at PORTB 4 - 7 = 19KHZ,57KHZ,133KHZ and 95Khz, the sum for each side (PORTB0-3 and other side (portb4 -7) is 304Khz.
Do you have any idea what code will i using to make it work.
It's possible to using PWM for multiple PORTB?
SherpaDoug
PostPosted: Wed Aug 08, 2007 11:55 am     Reply with quote
It sounds like you are going to have to get real familiar with the hardware of your PIC. The data sheet is only 128 pages as that chip is fairly simple. I suggest you read all about how its clocks and timers work, an afternoon's reading. It will be a good investment for any PIC work in the future.
(Print relevant sections to paper or you will go mad trying to make sense of it on a PC screen.)
blinkstar88
PostPosted: Thu Aug 09, 2007 6:29 am     Reply with quote
Thanks,
I was read all the datasheet, but i'm still not get the light :( .May be a little code give me away where to start.
