The Puma
Joined: 23 Apr 2004 Posts: 227 Location: The Netherlands
Hardware PWM 100Hz, 50% duty |
Posted: Sun Aug 05, 2007 2:23 pm |
How can i made this?
Hardware is:
PIC18F4620 with 20Mhz Crystal |
Posted: Sun Aug 05, 2007 5:15 pm |
This post has the formula to calculate the PWM frequency:
http://www.ccsinfo.com/forum/viewtopic.php?t=17993
To find the lowest possible PWM frequency for a 20 MHz crystal,
just put the following values into the equation:
Crystal frequency: 20,000,000 Hz
PR2 value: 255
Timer2 prescaler: 16
Then calculate the result. |
The Puma
Posted: Sun Aug 19, 2007 6:53 am |
Then this is the lowest freq 1220Hz? |
Posted: Sun Aug 19, 2007 7:44 am |
With that clock, and that chip, in PWM mode, yes.
However there is a solution, provided you are not using timer3. In _CCP_ mode (as opposed to PWM mode), the module can be programmed to use timer1 or timer3, instead of timer2 as it's source. If you program it in this mode, to drive the output high on address match, then have a CCP interrupt handler, which changes it to drive the output low on match (and back again on the next call), much slower frequencies can be achieved. (potentially down to 20000000/4/8/65535/2 Hz).
Even easier, just program a Timer2 interrupt at 200Hz, and toggle the output pin in this. Downside is that the output timing, can be fractionally affected by other interrupts (whereas the CCP version gives accurate timings).
Posted: Sun Aug 19, 2007 8:49 am |
Or use a slower crystal.
Why is it that everybody wants to use the highest clock frequency possible? At half the clock frequency your PIC will consume half the power, meaning a cheaper power supply, longer battery life, less heat generated and you will help to save the environment as well. For a 100Hz PWM you can reduce the clock to 1MHz, save 95% on power consumption and still have lots of processing power for other functions. |
The Puma
Posted: Sun Aug 19, 2007 10:11 am |
@Ttelmah
Can you give me an example code how that is done
Let say for 10Hz
Then i can play with that code for other freq. |
Posted: Tue Aug 21, 2007 5:16 am |
OK. No guarantees!....
//add processor definition here
int1 toggle=0;
#int_CCP1
void CCP1_isr(void)
if (toggle) {
//On alternate interrupts, set back to set the pin.
toggle=0;
setup_ccp1(CCP_COMPARE_SET_ON_MATCH);
//The first time the interrupt occurs, the output pin has been _set_, and
//we arrive here. Reprogram the CCP, to clear the pin next time
else {
toggle=1;
setup_ccp1(CCP_COMPARE_CLR_ON_MATCH);
//Adjust the setups t suit your chip
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
//No guarantees that the compiler realises that is has to do this,
//so setting TRIS manually.
set_tris_c(0xFB);
set_timer1(0);
CCP_1=31250;
clear_interrupt(INT_CCP1);
enable_interrupts(INT_CCP1);
//Using Timer 1 (change the CCP setup, if you want to use Timer3)
//Timer1, will count in steps of 20000000/4/8
//to give (say) 10Hz, we want a _half cycle_ of 50mSec. The
//count needed
//for this is 50E-3/(1/(20000000/4/8)) = 31250
while (TRUE) {
//rest of code here
Now, the 'key', is that the hardware sets or resets the pin, on the defined count. At the same time an interrupt is triggered, depending on what else is going on (other higher priority interrupts etc.), _so long as the interrupt handler is reached, before the count once again triggers the CCP_, we can reverse the operation to happen at this point. Hence on the first pass, I set the pin, then next time, reset it, etc. etc.. So the CCP, represents 'half cycle' time. Because the CCP, allows 16 bit compare values, and uses Timer1, or Timer3, The longest 'half cycle' possible, is just over 100mSec, allowing down to about 5Hz operation from a 20MHz clock. :-)
The Puma
Posted: Tue Aug 21, 2007 10:18 am |
Ok thanks, i will playing with it |
