multi servo motor driving
rnome
PostPosted: Sat Aug 04, 2007 6:51 am     Reply with quote
hi everybody
i m trying to make robot arm with servo motors but i cant find anyway to drive more than 2 servos
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include <lcd.c>
int x,pot0,pot1,i;
int16 srv1, srv2;
float kx;
#int_RDA
void RDA_isr()
      x=getc();
void data_bekle()     //for my RF hardware (not matter)
     for(;;){
        if(x==85)break;
    for(;;){
       if(x==255)break;
    for(;;){
       if(x!=255)break;
void servo1(int value){
   if(value<=127){
         kx=value/127.0;
         srv1=500+(int16)(kx*1000);
   if(value>127){
         kx=value/127.0;
         srv1=1500+(int16)((kx-1)*1000);
   for(i=0;i<1;i++){
        output_high(pin_d2);
         delay_us(srv1);
         output_low(pin_d2);
         delay_us(3000-srv1);
         delay_ms(17);
void servo2(int value){
   if(value<=127){
         kx=value/127.0;
         srv2=500+(int16)(kx*1000);
   if(value>127){
         kx=value/127.0;
         srv2=1500+(int16)((kx-1)*1000);
   for(i=0;i<1;i++){
        output_high(pin_d3);
         delay_us(srv2);
         output_low(pin_d3);
         delay_us(3000-srv2);
         delay_ms(17);
   enable_interrupts(INT_RDA);
   for(;;)
         data_bekle();
         pot0=x;
         data_bekle();
         pot1=x;
         servo1(pot0);
         servo2(pot1);
         lcd_gotoxy(1,1);
         printf(lcd_putc, "y=%u   x=%u   \ns1=%lu s2=%lu   ",pot0,pot1,srv1,srv2);
i wrote these codes and it works good but sometimes servos are shaking although values are constant on lcd
On the code servo1() and servo2() functions are generating servo delays for pwm that coming axis datas from a analog joystick.
is there anyone to help me about multiple servo driving algorithm
live fast, never rest and do your best
PostPosted: Tue Aug 07, 2007 5:02 pm     Reply with quote
You could look for CCS code with http://www.google.com by using
this search string:
"#use delay" int char servos
Here's one result, where someone is trying to emulate an SSC servo
controller.
http://academic1.bellevue.edu/robots/ssc5a.c
Not all of the code in there may be useful. He's created his own UART,
because he's doing it all in a PIC that doesn't have hardware UART.
The remainder of his code may need some improvement too, but at
least it can give you some ideas.
Notes on SSC servo controllers:
http://www.seetron.com/ssc_faq.htm
http://www.trossenrobotics.com/store/p/3191-SSC-32-Servo-Controller.aspx
