Problem sending "carriage return" via SIOW
cyberant
PostPosted: Fri Jul 27, 2007 8:13 am     Reply with quote
Sinple question =)
How can i send a 13 via the ASCII line in SIOW? - it always sends a 1 and a 3.
I want to control my programm via the pc which works fine, but the problem is that I need a carriage return behind every command.
It works if I send my command in the ASCII line and then change in the Hex line and send the 0D - but doing this everytime is not so nice...
treitmey
PostPosted: Fri Jul 27, 2007 8:32 am     Reply with quote
pressing the enter should send the 0x0d.
I have a loopback cable on my system right now.
I can type stuff and i see it at the other port, and
when I press enter i see the 0x0d
Make sure you have view hex turned on,.. then you can see the REAL data.
cyberant
PostPosted: Wed Aug 01, 2007 2:52 am     Reply with quote
Sorry nearly forgot this post, but i still have the Problem.
Here pressing enter makes the same thing as pressing send - no 0D or 13 gets send. Confused
PostPosted: Wed Aug 01, 2007 5:25 am     Reply with quote
Make sure the keyboard focus is not on a button or other edit component, try clicking once on either the transmit window or receive window. When I do this I see the TXD symbol on the Window bottom light up for every key press, including the enter key. Is this TXD symbol lighting up in your system?
cyberant
PostPosted: Thu Aug 02, 2007 12:31 am     Reply with quote
Ah that was the problem - thanks.
You have to click on the hex view first and then type without seeing what you type...then it works. Very Happy
Would be nice if someone also know how to send a 13(0D) in the asci line? - but its not so bad as before.
