Joined: 30 Jul 2007 Posts: 112 Location: Moscow, Russia
Please, help me with making hysteresis!
Posted: Wed Aug 01, 2007 6:01 am
I need to implement hysteresis in termoregulator device. I have desired temp (Td), current temp (Tc) and Delta Td (hysteresis).
libor
Posted: Wed Aug 01, 2007 9:46 am
Do you read current temp as an analog input using the A/D ? I suppose you want the hysteresis done in software, and you are controlling a digital port.
You can define the two levels for the switching and use the according level depending on the current state (ON or OFF) of the state machine.
#define OFF 0
#define ON 1
int state;
lowerlimit=Td-delta;
upperlimit=Td+delta;
if (state == ON) {
if (Tc>upperlimit) {
state = OFF;
//... turn off heating
if (state == OFF) {
if (Tc<lowerlimit) {
state = ON;
// ...turn on heating
if you are controling an analogue output like a PWM output I would rather suggest to use a PID algorythm instead calculating the error and acting upon it.
40inD
Posted: Wed Aug 01, 2007 12:22 pm
Thanks! It works.
(I use DS18B20, but it's no matter)
