Timer problem
deniska_gus
Timer problem
PostPosted: Mon Jul 30, 2007 1:46 am     Reply with quote
Hello dear frends!
I have one problem. I have to program this situation, but i have no idea how i can realize it. It should work so:
If i push a button AND i hold it pushed for 5 sec. a LED should start lighting.
Any suggestions?
Thank you. Dennis
inservi
PostPosted: Mon Jul 30, 2007 2:12 am     Reply with quote
I think that a good way is to use an interrupt for counting the time.
For example, set one timer for about 0.76 second and use a int16 counter in the interrupt. when the counter count at least 380 the the 5 second are past
You can check if the button is pushed in he interrupt. If the button is not pushed then set the counter to 0.
In the main loop you can testing if the counter is greater than 380 then set the led on...
 int16 sec5 = 0 ;
  #INT_TIMERx
  void interrupt_proc() {  // called n time by sec (for example)
   if (button_pushed) ++sec5 ;
     else sec5 = 0 ;
  until(true) {
    if ( sec5 >= ( n*5 ) ) { // n is the number of time that the interrupt is called by second
      // your code for led ...
Witch pic do you use ? (i suppose that you use a pic16f873 ?)
dro.
in médio virtus
deniska_gus
PostPosted: Mon Jul 30, 2007 2:17 am     Reply with quote
Thank you very much. I will test it. I use PIC16F877A
