Interrupting SPI routines
DonWare
PostPosted: Fri Jul 27, 2007 3:14 pm     Reply with quote
Hi, I'm using SPI and the CCS SPI routines to talk to a Microchip EEPROM.
Processor in this case is a 16F877 but may be an 18F452 later.
My code to r/w the eeprom is running fine now with nothing else going on.
My project uses tx and rx serial interrupts and also timer0 to generate an operating system timebase.
Is it OK to interrupt the SPI read and write routines this way ?
Thanks, Don
PostPosted: Fri Jul 27, 2007 3:54 pm     Reply with quote
1. What's the part number of the eeprom ?
2. Are you using hardware or software SPI ?
3. If you're using hardware SPI, what clock divisor are you using in
your setup_spi() statement ?
4. Are you using a CCS driver ? Which one ?
5. What is the oscillator frequency of your PIC ?
