Strings in function act as if they are STATIC, but are not!
jseidmann
PostPosted: Fri Jul 27, 2007 11:57 am     Reply with quote
I have a function in my code that does some work with strings, and I declare two strings in the function (s[4 and sTemp[8]). For some reason, I declare these two normally:
char s[4];
char sTemp1[8];
The problem is that I would assume that whenever i go into these functions, that they should be all full of null values whenever I start the function, but when I enter this function the second time, they still have the same value as before, so I have to clear them! Is this how its supposed to be? It doesnt make sense to me. I dont declare them as static variables!
PostPosted: Fri Jul 27, 2007 12:10 pm     Reply with quote
If local variables in a function are not declared as 'static', the RAM used
by them is released by the compiler, upon exiting from that function. The
RAM can then be used for local variables in other functions or in main().
There is no requirement for the compiler to set the value of the released
RAM bytes to zero. All local variables (that are not static) must be
initialized by you, with lines of code, upon entry into the function.
This behavior is part of the C language.
jseidmann
PostPosted: Fri Jul 27, 2007 12:12 pm     Reply with quote
Is there an easy way to initialize them? Is there a function built in to do so?
Douglas Kennedy
PostPosted: Fri Jul 27, 2007 12:24 pm     Reply with quote
Read the manual maybe #ZERO_RAM is for you or
char s[5]={'t','e','s','t'};
PostPosted: Fri Jul 27, 2007 12:30 pm     Reply with quote
Here are some ways to do it. The one that uses the least amount of
ASM code is the first method, shown below (at least for small arrays):
void my_func(void)
int8 i;
char s[4];
char sTemp1[8];
s[0] = 0;
s[1] = 0;
s[2] = 0;
s[3] = 0;
for(i = 0; i < sizeof(s); i++)
    s[i] = 0;
memset(s, 0, sizeof(s));
Pret
PostPosted: Mon Jul 30, 2007 5:43 am     Reply with quote
If you are working with string functions, is enough to use s[0] = 0; or char s[4] = "";
