control DC110 motor
whung.john
control DC110 motor
PostPosted: Mon Jul 23, 2007 10:53 am     Reply with quote
Very Happy
hi ,all my friends.
because i think use DC110 motor to control a machine.
i uses electric parts follow as;
from pic16f73 to moc3023,and use moc3023 control triac .
use triac part to control my dc110 motor.
but i dont understand ,how to write program.
i tried written porgram.and not use ccp1 direct to control DC110 motor.
i used pin A1 to connect motor.
please tell me ,where have bug error.
very thanks u read my question contents.
#define PWM_PIN PIN_a1
#define LOOPCNT 50
int8 width;
#INT_RTCC
void tick_interrupt(void);
main()
width = 10;
setup_counters(RTCC_INTERNAL, RTCC_DIV_1);
enable_interrupts(INT_RTCC);
#INT_RTCC
static int8 loop = LOOPCNT;
static int8 pulse;
if(--loop == 0)
loop = LOOPCNT;
pulse = width;
if(pulse)
output_high(PWM_PIN);
pulse--;
output_low(PWM_PIN);
PostPosted: Mon Jul 23, 2007 12:54 pm     Reply with quote
110VDC or 110VAC ?
I don't think you can use a triac for regulating a DC motor. Once triggered a triac will only shut down when the current goes down to zero, this will never happen with a DC voltage.
If you meant AC, then you will need some kind of synchronization to the power supply zero crossings.
whng.john
HOW TO ADJUST MOTOR SPEED
PostPosted: Mon Jul 23, 2007 6:33 pm     Reply with quote
ckielstra wrote:
110VDC or 110VAC ?
HI,MY friend.
the hareware use moc3023 control triac action operation,
and triac volt from BRIDGE 110VAC trans to 110vDC.
i use pic16f73 send a high or low. the moc3023 starts operation and
traic started volt output to my 110VDC MOTOR.
I think use software pwm method ,and i can control motor and adjust .
please u can tell me and teach me ,how can i solution my question from
adjust question.
now i tried control from my post infortion program.the motor can operation but motor operate not very smooth operation.
PostPosted: Tue Jul 24, 2007 4:14 am     Reply with quote
Even when using a rectifier bridge the DC voltage will continously vary from 0 Volts to the maximum. To get a stable motor regulation you will need some kind of synchronization with the mains voltage.
I'm no expert in this area. Maybe someone else can jump in?
SherpaDoug
PostPosted: Tue Jul 24, 2007 8:43 am     Reply with quote
ckielstra is right. If you try to use an unsynchronized PWM to control AC by a triac you will get a "beat note" as the AC and PWM clocks creep into and out of synchronization. I suggest you try these:
1) Get comfortable using PWM control of a small DC motor like in a toy car.
2) Try using a triac to control a 110VAC incandescent light bulb. A light bulb is a very easy load to drive, with minimal inertia, power changes are obvious, and it is electrically rugged and easy to replace if you find a way to damage it. Look at Microchip application note AN521 to see how to synchronize the PIC to the AC power line. I suggest you invest in an isolation transformer so you don't get shocked or blow up your PIC equipment if you touch a wrong wire.
3) Try controlling an AC brush motor like a lawn mower or vacuum cleaner motor.
4) Finally try your rectified AC drive of a DC motor.
WHUNG.JOHN
MAKE A ZERO
PostPosted: Wed Jul 25, 2007 5:50 am     Reply with quote
thank u teach me.
i even read a internal about eletric report.
it teach me ,my hardware need a scan a zero voltage.
so pic16f877 knows AC valtage started and start count time.
60hz about 16ms,and need make a delay time .
so hardware triac can get a middle valutage.
i try written programm. but motor operation dont smooth active.
my program here: follow as :
main()
if (!input(pin_a4)) //USE PIN_A4 TO SCAN AC110v START
delay_ms(10);
output_high(pin_a1); //connection TRIAC let AC MOTOR can operate pin
delay_ms(6)
output_low(pin_a1);
please teach me ,where have bug? and how to debug?
