strcmp() and strcmpy() functions on PIC12F509
typek
PostPosted: Tue Jul 24, 2007 6:35 am     Reply with quote
I'm trying to use two functions from string library.
strcmp() doesn't accept pointers to constant strings as an parameter
strcpy() accepts pointers to constant strings
Does anybody know the reason, both functions behave in a different ways?
There is information in CCS manual that CCS doesn't allow pointers to a constant to be used but why exception for strcpy()?
I'm using PCB V4.042 compiler.
PostPosted: Tue Jul 24, 2007 8:08 am     Reply with quote
So you can use the strcpy function to copy the constant to RAM, and then use the other functions on it there.
The function is 'under the skin', overloaded, with two different functions present. The first is the normal 'string' pointer version, while the other treats the source as a function returning a byte from an indexed location. This code makes the function bulkier (which is why it is only in this one function), but then allows it to be used to make the other functions work.
typek
PostPosted: Tue Jul 24, 2007 3:27 pm     Reply with quote
I've made a mistake in the subject of the post. The name of the second function is of course strcpy() and not strcmpy() which was obviously noticed by you.
Your explanation sounds logical. The idea of having just one function which can operate on constants is a bit irritating in use though;) I'd prefer not to be forced to waste RAM just on the temporary buffer for keeping copies of the strings. At least I know now that the way it works is intentional.
