jcsquire Guest
byte variable declaration gives compile error |
Posted: Sat Jul 21, 2007 11:03 am |
Hey all,
Sorry about this newbie post, but sometimes in the beginning we all have embarrassingly obvious questions. Mine is: why am I getting a compile error in this extremely simple first try program of mine?
int8 byteBCD;
The compiler warns me that a numeric expression must occur here. My code in full context is below...all is written by the wizard except for my simple variable declaration. Thanks from someone just getting started.
////////////// Chip setup //////////////
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_oscillator(OSC_1MHZ|OSC_TIMER1);
set_tris_a(0b00111100); // RA2-5 are BCD inputs, rest LED outputs
set_tris_b(0b00000000); // all are LED outputs
////////////// Local variables //////////////
int8 byteBCD;
Posted: Sat Jul 21, 2007 11:08 am |
Put all your local variable declarations at the beginning of the function.
Put your code after the variable declarations. |
Posted: Sat Jul 21, 2007 12:02 pm |
Thanks for getting me started, PCM Programmer, with your fast response! |
