Datman Guest
MPLAB 7.5 |
Posted: Wed Jun 20, 2007 4:56 pm |
are there any known issues using PCM with MPLAB 7.50? I purchased the PCM compiler this morning, have been successfully trying test code and programming a 16F877A. However MPLAB constantly crashes, and whenever i try to open the old project it says that the project is now corrupt... so after every crash I have to create a new project and re-add my source files ( which are still ok )... any ideas...? happens at random every half hour or so |
kevcon
Joined: 21 Feb 2007 Posts: 142 Location: Michigan, USA
Posted: Thu Jun 21, 2007 7:05 am |
7.61 is a bit more stable, it mainly crashes when I'm programming a chip.
The one thing I really like about 7.61 is dockable windows; which allows you to use multiple monitors |
YUM
MPLAB crash |
Posted: Wed Jul 11, 2007 5:37 am |
I used MPLAB 7.50, 7.61a in conjunction with CCS 3.227 on Windows XP.
It crashed every few minutes, always when i pressed the programming tab or the compiling tab.
Of course i have read nearly everything on the internet and tried a lot.
Finally it only helped to:
-) uninstall ALL, manually cleaned the registry (cleaned everything with "MPLAB", "Microchip", "CCS")
-) reinstall MPLAB 7.20 (!!!) - restart windows
-) reinstall CCS 3.227 - restart windows
-) reinstall MPLAB plugin - the old one (!!!) which has 299.304 bytes
now i work on my project for some days, w/o a single crash.
I have to mention that i also gave more virtual memory.
I hope doing the same way can help you, too. ![Cool](images/smiles/icon_cool.gif) |
Humberto
My too !!! |
Posted: Thu Jul 19, 2007 12:51 pm |
Well, after some "cleanning" in my Vaio, I reinstalled all my tools and programs.
The point is that I didn´t keep the "old" MPLAB/CCS plugin wich I used to use,
instead I installed the last and fresh MPLAB plugin version wich is the only
available in the site.
After that I realized that I´m in the same problem, the suit MPLAB/ICD2 that
I use to debug, start crashing. I´m using CCS V3.236.
I search in Microchip/MPLAB site but they do not keep old plugins versions too.
Pls, somebody can point me where/how can I get the old one ?
Many thanks in advance,
Humberto |
treitmey
Posted: Thu Jul 19, 2007 2:58 pm |
see your private messages. |
Humberto
Posted: Thu Jul 19, 2007 3:04 pm |
Hi treitmey,
Many thanks !!!
Now I learned the lesson... (one more!!!)
In my next life -if so- for sure, I will be a carpenter !!!
Humberto |
Bill Boucher
Joined: 04 Feb 2005 Posts: 34 Location: Chatham,ON,CA
Posted: Thu Jul 19, 2007 5:46 pm |
treitmey wrote: | see your private messages. |
I wouldn't mind seeing that private message myself. I'm in the same boat along with several others both at home and at the automotive company where I work. We are all using CCS under MPLAB under XP and they all crash randomly and often, regardless of PC manufacturer. |
treitmey
Posted: Fri Jul 20, 2007 7:47 am |
sure,
I just wasn't too keen on my personal web page given
its not that professional. I'm learning c# so I don't have much free time
CCS mplab_plugin sized 299.304 bytes
http://xxx.googlepages.com ...(edited)(link removed)
I hope this fixes the problem. Report back |
DMX_MODBUS Guest
Version 7.6+ issues |
Posted: Thu Jul 26, 2007 10:10 am |
I was having massive lockup issues with 7.6+. As suggested, I uninstalled
7.6, went through the registry and removed any (obvious) leftover MPLAB
entries (and there were plenty). There were some entries that I wasn't sure
about... i.e. CCS references to MPLAB, so I left anything that wasn't
obviously installed by microchip. I then removed/uninstalled the CCS compiler as a JUST-IN-CASE. Reinstalled 7.41, reinstalled CCS (latest
version). Ran the OLD CCS mplab utility. Everything is now stable and
have not had a lockup yet. The only extra thing I had to do was manually
change where MPLAB looked for compiler. It defaulted to pointing to the
included basic CCS compiler, and it had to be directed to the PICC
folder. CCS tech support helped out on that one.
The nice gentleman at Microchip that tried
to help me with the "trouble ticket" seemed "baffled". It wasn't until I put
forth a little more effort to track down the problem myself and search google that I found the boards here as well as microchip... and a few other places as well. With so many postings HERE as well
as on the microchip message boards in relation to lock up issues with 7.5
and greater, I was disappointed how clueless they were about the situation.
Perhaps 7.7... 7.71...??
-working |
