Convert 4 hex bytes to float
The_Todd
PostPosted: Wed Jul 18, 2007 11:51 pm     Reply with quote
I have a compass that outputs via serial a binary string containing the IEEE 754 standard binary representation of a float.
An example is:
43 81 81 9C
representing 259.01257 degrees
My issue is I cannot transform those four bytes into a float variable.
Things I've tried:
put the bytes into an array, and then make a pointer to a float variable, and try to set float bits using memset() - no effect
use bit_set() to try and set each bit in a float - doesn't affect it
Heres some sample test code maybe you could modify.
#include <18F4520.h>
#device ICD=TRUE
#FUSES HS,NOWDT,DEBUG,MCLR
#use rs232(DEBUGGER)
int parts[4] = {0x43,0x81,0x81,0x9C}; //four bytes representing a float
int i=0;             //counter used in for loops
float heading = 0;   //the desired float to set
int *headingPtr;
int exponent = 0;
int sign = 0;
headingPtr =& heading;
//try using a pointer
for(i=0;i<4;i++)
memset(headingPtr,parts[i],8);
headingPtr++;
printf("heading1:%f\r\n",heading);
//try to set bits individually - float should equal 4
bit_set(heading,30);
bit_set(heading,25);
printf("heading2:%f\r\n",heading);
I appreciate it greatly!
Todd
PostPosted: Thu Jul 19, 2007 1:55 am     Reply with quote
The best thing to use is a union. If you have:
union joiner {
    int8 b[4];
    float fp;
    word w;
} combine;
Then you can write bytes into combine.b[0] to combine.b[3], and access the created float with combine.fp
Unfortunately (there has to be a downside...), CCS, doesn't use IEEE format floats. Fortunately, there is a library called 'ieeefloat.c', with the compiler to do the conversion (or I have published routines here in the past, before this came along, to do this). This library expects an int32 (hence my inclusion of the 'w' int32 int the above, so write the bytes into the four b values, and then call 'f_IEEEtoPIC' from this library, which does the bit re-shuffling needed to convert the type, and returns a PIC float.
ljbeng
PostPosted: Thu Jul 19, 2007 10:31 am     Reply with quote
I have what you need but I can't get the code to display correctly...
This is weird but I had to take out less-than characters.... Where you see
temp .. 1
replace with
temp (less than)(less than) 1 (shift left 1 bit)
float f_IEEEtoPIC(int32 f)
   float ret;
   int16 temp;
   memcpy(&temp, ((int8*)&f)+2, 2);
   temp = ((temp .. 1) & 0xFF00) + (temp & 0xFF);
   if(bit_test(f, 31))      // Test the sign bit
      temp |= 0x0080;
      temp &= 0xFF7F;
   memcpy(((int8*)&ret)+3, ((int8*)&f)     , 1);
   memcpy(((int8*)&ret)+2, ((int8*)&f)+1   , 1);
   memcpy(((int8*)&ret)+1, ((int8*)&temp)  , 1);
   memcpy(((int8*)&ret)  , ((int8*)&temp)+1, 1);
   return ret;
int32 f_PICtoIEEE(float f)
   int16 c[2];
   memcpy((int8*)c  , ((int8*)&f)+3, 1);
   memcpy((int8*)c+1, ((int8*)&f)+2, 1);
   memcpy((int8*)c+2, ((int8*)&f)+1, 1);
   memcpy((int8*)c+3, ((int8*)&f)  , 1);
   c[1] = ((c[1] >> 1) & 0x7F80) + (c[1] & 0x7F) + ((c[1] & 0x80) << 8);
   return ((int32)c[1] << 16) | c[0];
main(){
   i32val = make32(0x43,0x81,0x81,0x9C);
   compass = f_IEEEtoPIC(i32val);
PostPosted: Thu Jul 19, 2007 11:47 am     Reply with quote
This is caused by the text being interpreted as HTML code. Solution: on posting select the 'Disable HTML in this post' checkbox, or even better, select this option as default in your profile.
Ken Johnson
PostPosted: Thu Jul 19, 2007 5:51 pm     Reply with quote
look at ieeefloat.c in the drivers folder
Ken
Douglas Kennedy
PostPosted: Fri Jul 20, 2007 1:56 am     Reply with quote
In floating pt the mantissa is normalized ( the exponent is adjusted to guarantee a 1 in the msb position of the mantissa). This is like writing the value in binary notation as 0.1nnnnnnnn to 23 bits raised to some power of two encoded in the exponent byte with an offset of 127 to allow for both positive and negative exponents. A special case for the exact value zero is allowed for.
The sign of the non zero values are stored as bit of the mantissa.Now with 4 bytes of storage there are choices as to what is done ... like does the exponent go in the first byte or in the last byte so we need standards to identify the coding scheme. Another wrinkle is since the normalized mantissa always has its most significant bit as a 1 use can be made of it. It can be replaced by the sign of the mantissa effectively gaining 24 bit precision at the expense of processing cycles since the sign would have to be extracted prior to doing any arithmetic with it. CCS uses 23 bit and uses an unadjusted normalized mantissa. The conversion routine ieeefloat.c in the drivers folder takes the work out of this for us.
