too high power consumption in sleep mode
PIC16F917 sleep mode
PostPosted: Mon Jul 16, 2007 3:20 pm     Reply with quote
Hi, I am experiencing the power consumption problem when PIC16F917 goes to sleep mode. Assume the circuit is correctly. How can I prepare a simple code which just runs to sleep and make it run on the lowest power consumption. Here's my code, but it shows too high of power consumption...
//#fuses NOWDT,INTRC_IO, NOPUT, NOPROTECT, NOMCLR, NOCPD, BROWNOUT, NOIESO, NOFCMEN, NODEBUG
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_c(0xFF);
set_tris_d(0xFF);
set_tris_e(0xFF);
B_ANSEL=0x00;
SLEEP(); //Get in Sleep mode
I appreciate anyone can give any idea of it.
Thanks.
Bob
PostPosted: Mon Jul 16, 2007 3:40 pm     Reply with quote
What level of current do you measure in sleep mode ?
Also your #fuses statement is commented out. What are your
actual fuse settings ?
See these threads for ideas:
http://www.ccsinfo.com/forum/viewtopic.php?t=24562
http://www.ccsinfo.com/forum/viewtopic.php?t=23376
Bill Boucher
PostPosted: Tue Jul 17, 2007 10:32 am     Reply with quote
Also be aware that if your ANx pins are set to digital mode, don't leave them floating or the logical input buffers may draw excess current. Unused and unconnected pins can be forced to a valid high or low state by programming them as outputs. That will prevent floating so that no external pullup or pulldown resistors are needed. If you want to leave them floating (for some unknown reason) then program them as analog mode (that's the default mode I think) and the input buffers will be shut off and that will also prevent undue current draw.
