run in debug mode but not in normal mode
virkom
PostPosted: Wed Jul 11, 2007 3:20 am     Reply with quote
Hello!
I have a big problem...
I have written a program for a PIC18F258 that consists in switch on some leds, but it only runs in debug mode... when I want to program the pic in normal mode, the pic doesn`t switch on the leds. The corresponding pins are floating, so sometimes the leds shine and sometimes donĀ“t...
What would be the problem? I check all the circuit and there aren`t any shorcut, i have changed the pic but it isn`t the problem...
Could the oscillator be the problem?
Thank you everybody and sorry about my english... I am spanish
PostPosted: Wed Jul 11, 2007 4:14 am     Reply with quote
Which programmer are you using?
Which IDE are you using? (MPLAB or the CCS IDE?)
PostPosted: Wed Jul 18, 2007 5:05 pm     Reply with quote
Hi
Had same problem, if using MPLAB and ICD 2 switch from debugger to progammer mode and all should work fine.
