CAN Problem? How to work 18F2431 +mcp2515
longmenok
PostPosted: Tue Jun 19, 2007 10:36 am     Reply with quote
Hello! I have a work about CAN communication.
The following is my code. If it were used for 16F877A, it are good!
But it arenot work for 18F2431
I want to know how to correct it.
Thanks ,say sorry to my poor english.
osc=20M mcp2515 20M CAN bitrate =500K
2431 -----> 2515
PIN_C6(17) ----->> CS(16)
PIN_C7(18) ----->> SI(14)
PIN_C4(15) ----->> SO(15)
PIN_C5(16)----->> SCK(13)
PIN_C3(14) ----->> INT(12)
transmit code
#include <18F2431.h>
#fuses HS,NOPROTECT,NOLVP,NOWDT
#include "MCP2515.c"
//                               main code                              //
 unsigned char buffer[2]={0x19,0x82};
 output_low(PIN_C1);
 setup_adc_ports(NO_ANALOGS);
 setup_adc(ADC_OFF);
 setup_spi(FALSE);
 can_init();
      if(can_tbe())
          can_putd(0x201,&buffer[0],2,3,0,0);
         // receive ID 201 is good.
          delay_ms(900);
          output_high(PIN_C1); //led on
          output_low(PIN_C1);  //led off
"MCP2515.c"
#ifndef EXT_CAN_CS
//18F2341
   #define EXT_CAN_CS   PIN_C6
   #define EXT_CAN_SI   PIN_C7
   #define EXT_CAN_SO   PIN_C4
   #define EXT_CAN_SCK  PIN_C5
void can_set_baud(void) {
   struct struct_CNF1 new_CNF1;
   struct struct_CNF2 new_CNF2;
   struct struct_CNF3 new_CNF3;
//use MBtime setup CAN Bitrate  osc=20M bitrate=500k
   new_CNF1=0x00;
   new_CNF2=0xBA;
   new_CNF3=0x07;
   //other codes are the  same as can-mcp251x.c
MBTIME Download
http://www.intrepidcs.com/index.php?name=CmodsDownload&file=index&req=viewdownload&cid=2&orderby=dateD
longmenok
PostPosted: Mon Jun 25, 2007 9:30 am     Reply with quote
help
PostPosted: Mon Jun 25, 2007 11:26 am     Reply with quote
But it are not work for 18F2431.
Does the only difference between the two programs consist
of the #include file line ? Other than that, are the two programs
completely identical ?
or
#include <16F877A.h>
Are the hardware connections between the PIC and the MCP2515
the same, for the 18F2431 and the 16F877A ?
Is the MCP2515 circuit the same, for each PIC ?
Does the MCP2515 have a 20 MHz crystal in each case ?
In other words, you said it works for 16F877A, but I want to get
a confirmation from you that the only thing you changed for the
new project is the PIC, and the #include statement.
Also, post the CCS compiler version that you used with each PIC.
longmenok
PostPosted: Sun Jul 08, 2007 9:53 pm     Reply with quote
MCP2515 is used. can-mcp2510.c is modified as following.
can-mcp2510.c connect with 16F877A is following
//877A IO pins connected to MCP2515
#ifndef EXT_CAN_CS
   #define EXT_CAN_CS   PIN_A5
   #define EXT_CAN_SI   PIN_C5
   #define EXT_CAN_SCK  PIN_C3
  // mcp2515's PIN INT connect with 877A's RB0
set_baud
   new_CNF1=0x00;
   new_CNF2=0xBA;
   new_CNF3=0x07;
   MCP2515_write(CNF1, (int)new_CNF1);
   MCP2515_write(CNF2, (int)new_CNF2);
   MCP2515_write(CNF3, (int)new_CNF3);
can-mcp2510.c connect with 18F2431 is following
//18F2431 IO pins connected to MCP2515
#ifndef EXT_CAN_CS
//2341
   #define EXT_CAN_CS   PIN_C6   //SS
   #define EXT_CAN_SI   PIN_C7   //SDO
   #define EXT_CAN_SO   PIN_C4   //SDI//SDA
   #define EXT_CAN_SCK  PIN_C5   //sck/scl
    //mcp2515' PIN INT connect with 2431's RC3
the above is the difference for their connect
18F2431'baud is the same as 16F877A
the following is code for 16F877A and 18F2431 to transmat
#include "can-mcp2510.c"
//                                main code                               //
 output_low(PIN_C1);
 setup_adc(ADC_OFF);
 setup_psp(PSP_DISABLED);
 setup_spi(FALSE);
 can_init();
      if(can_tbe())
          can_putd(0x722,&buffer[0],2,3,0,0);
          delay_ms(900);
          output_low(PIN_C1);
//                                main code                                //
 setup_adc(ADC_OFF);
 setup_spi(FALSE);
 can_init();
         if(can_tbe())
the following is code for 18F458 to receive //correct it
#include <18F458.h>
#include "can-18xxx8.c"
// set baud in Ccan-18xxx8.c
//  BRGCON1 = 0x00;
//  BRGCON2 = 0xBA;
//  BRGCON3 = 0x07;
///               main code                                //////
 struct rx_stat rxstat;
 int32 rx_id;
 unsigned char buffer[2];
 unsigned char rx_len;
 output_low(PIN_D1);
 setup_adc(ADC_OFF);
 setup_spi(FALSE);
 can_init();
      if(can_kbhit())
        if(can_getd(rx_id,&buffer[0],rx_len, rxstat))
          if((rx_id==0x722)&&(buffer[0]==0x19)&&(buffer[1]==0x82))
            output_high(PIN_D1);
            output_low(PIN_D1);
Thanks! PCM programmer
longmenok
PostPosted: Tue Jul 10, 2007 7:38 pm     Reply with quote
Can you help me! Thanks!
PostPosted: Wed Jul 11, 2007 11:57 am     Reply with quote
The following is code for 16F877A and 18F2431 to receive:
#include <18F458.h>
// BRGCON1 = 0x00;
// BRGCON2 = 0xBA;
// BRGCON3 = 0x07;
The can-18xxx8.c file only works with 18F chips that have a built-in
CAN module. The 16F877A and 18F2431 do not have one.
This code will not work with those two PICs.
longmenok
PostPosted: Thu Jul 12, 2007 1:10 am     Reply with quote
I use 18F2431+mcp2515 to transmit motor QEI data, and use 18F458 to receive data. when I use 16F877A+mcp2515, CAN Communication can good work. However I use 18F2431+mcp2515 , 18F458 can't receive any data.
IN transmit code use "can-mcp2510.c" for 18f2431
and in receive code use "can-18xxx8.c" for 18f458
their bauds are same,
Transmit by 18F2431
   new_CNF1=0x00;      //Set baud
   new_CNF2=0xBA;
   new_CNF3=0x07;
Receive by 18F458
//  BRGCON1 = 0x00;  set baud
//  BRGCON2 = 0xBA;
//  BRGCON3 = 0x07;
why 18F2431 can't communiate?
Thanks! PCM programmer.
longmenok
PostPosted: Thu Jul 12, 2007 2:01 am     Reply with quote
I test it, can_init() can't good work.
In can_mcp2510.c
void can_set_mode(CAN_OP_MODE mode) {
   struct struct_CANCTRL old_CANCTRL;
   old_CANCTRL=MCP2515_read(CANCTRL);
   old_CANCTRL.reqop=mode;
   MCP2515_write(CANCTRL, (int)old_CANCTRL);
   do {
      old_CANCTRL=MCP2515_read(CANCTRL);  // In there,  it is always LOOP
      } while (old_CANCTRL.reqop != mode);
PostPosted: Thu Jul 12, 2007 10:23 am     Reply with quote
See this post. It has links to trouble-shoot problems with can_init():
http://www.ccsinfo.com/forum/viewtopic.php?t=30107&start=5
