EEPROM 24C512 R/W Problem, Need Help
AdamkT1
PostPosted: Sat Jul 07, 2007 3:59 am     Reply with quote
I am trying to develop the driver for 24C512 EEPROM but so far I am having problems.
My desire is to write and read from the address 1.
Need help...
Below is the code:
#include <18F452.h>
#include "24C512.c"
   int8 n;
   EEPROM_ADDRESS address;
   SET_TRIS_A(0);
   SET_TRIS_C(0);
   SET_TRIS_D(0);
   PORTA=0xFF;
   PORTB=0xFF;
   PORTC=0xFF;
   PORTD=0xFF;
   delay_ms(500); //let the system to stabilize
   address=1;
   PORTC=0;
   PORTD=0;
   while (TRUE)
      for (n=1; n<100;n++)
         write_ext_eeprom(address, n);
         PORTC=n;
         delay_ms(200);
         PORTD=read_ext_eeprom(address);
         delay_ms(200);
      }//end for
   }//end while
========24C512.C=================
#ifndef EEPROM_SDA
#define EEPROM_SDA  PIN_B1
#define EEPROM_SCL  PIN_B0
#define EEPROM_ADDRESS long int
#define EEPROM_SIZE   65535
void start_ext_eeprom()
   output_low(EEPROM_SCL);
   output_high(EEPROM_SDA);
   output_high(EEPROM_SCL);
   delay_ms(1);
   output_low(EEPROM_SDA);
   delay_ms(5);
void stop_ext_eeprom()
   delay_ms(1);
   delay_ms(5);
void clock_data(Byte data)
   int8 ctr;
   for(ctr=0; ctr<8; ctr++)
      output_bit(EEPROM_SDA, shift_left(&data,1,0));
      delay_ms(1); // let the pin stabilize
      delay_ms(1); //let the pin stabilize
   delay_ms(5); // delay for EEPROM write cycle
void write_ext_eeprom(long int address, BYTE data)
   start_ext_eeprom();
   clock_data(0xa0);  // Device address & R/w bit is low
   while (input(EEPROM_SDA));
   clock_data(address>>8);
   clock_data(address);
   clock_data(data);
   stop_ext_eeprom();
BYTE read_ext_eeprom(long int address)
   int8 ctr;
   BYTE data;
   start_ext_eeprom();
   clock_data(0xa0);  // Device address & R/w bit is High
   start_ext_eeprom(); //Send start again
   clock_data(0xa1);  // Device address & R/w bit is low to READ
   //===========read the data===================
      shift_left(&data,1,input(EEPROM_SDA));
      delay_ms(1); // let the pin stabilize.
   stop_ext_eeprom();
   return(data);
PostPosted: Sat Jul 07, 2007 10:49 am     Reply with quote
You're not using the CCS driver.
Use the CCS driver. Here's the file location:
c:\Program Files\PICC\Drivers\24512.c
AdamkT1
PostPosted: Sat Jul 07, 2007 6:04 pm     Reply with quote
I have tried the driver also but that too does not seem to work. The program just hangs in the first write statement of the driver after the start statement.
Besides as a learner, I wish to do it myself.
Can some body highlight the mistake in the code?
The only idea left with me, is that may be, the pin SDA is not configured as an input that is why the value read is always a Zero.
Thanks for the reply. Rolling Eyes
PostPosted: Sat Jul 07, 2007 6:38 pm     Reply with quote
If the CCS driver doesn't work, then there is something wrong with your
hardware. That's why I suggested that you try it first. Now you should
look closely at your connections, etc. Do you have pull-up resistors
on the SDA and SCL lines ?
AdamkT1
PostPosted: Sat Jul 07, 2007 6:43 pm     Reply with quote
No pullups.
Can you provide me any hardware requirements.
Thanks again.
PostPosted: Sat Jul 07, 2007 6:45 pm     Reply with quote
Add a pull-up resistor to +5v on each of SDA and SCL. Use 4.7K ohm
resistors.
AdamkT1
PostPosted: Sat Jul 07, 2007 6:48 pm     Reply with quote
Ok.
I would need a little time to make that happen as I am not very good at hardware.
Appreciate the prompt responses. Thank you.
AdamkT1
PostPosted: Sun Jul 08, 2007 1:26 am     Reply with quote
Its working fine now.
Thanks for the support.
I wish I could send the proteus file for new comers, as I see that this topic has been discussed so many times.
Thanks again
Very Happy
