Some doubts regarding PCM 3.169 USART Bug ??
arunb
PostPosted: Wed Jul 04, 2007 11:12 pm     Reply with quote
MCU: 16F648A
PCM ver.: 3.169
I am aware that the PCM 3.169 compiler has a bug, when used with 16F648A, the USART functions like getc, putc etc. do not work, I have implemented the workaround for this (posted by PCM Programmer ina earlier post).
Now I am using RS 485 instead of RS 232, does the workaround need any changes (in RS 485 an enable pin is used, in my case it is pin_b5).
Kindly advise..
thanks
arunb
PostPosted: Wed Jul 04, 2007 11:50 pm     Reply with quote
When you refer to some posted code, you should provide a link to it:
http://www.ccsinfo.com/forum/viewtopic.php?t=26631&start=8
arunb
RE:
PostPosted: Thu Jul 05, 2007 12:23 am     Reply with quote
Thanks for the tip...
Will the code work for RS 485 as well...
arunb
PostPosted: Thu Jul 05, 2007 12:43 am     Reply with quote
No it won't. RS-485 uses an enable pin for the transmit driver.
You need to create a routine similar to the one shown in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=14445&highlight=trmt
arunb
RE:
PostPosted: Thu Jul 05, 2007 1:55 am     Reply with quote
I just noticed a problem in the receive routine using interrupt (INT_RDA).
While sending a stream of characters from the PC the PIC does not receive them correctly... but if the stream is slowed down , then the PIC receives the data correctly, is there any way to speed up the receive process. In the built-in getc function I didi not have this problem....
thanks
arunb
