PIC18F4550 bugs again & again !?
PICoHolic
PostPosted: Wed Jul 04, 2007 6:28 am     Reply with quote
Hey to all,
I've noticed that PORTB[0] behaves weirdly. when i write a value to PORTB, RB0 sometimes is correct some other times is not. At first i thought that the PIC is damaged until i tried another one. Same problem!
PORTB = Buff[i];
Going through the listing i've noticed that the instruction used is MOVFF
Any comments? Shocked
PostPosted: Wed Jul 04, 2007 8:29 am     Reply with quote
Every pin on portB, on that chip, has other devices multiplexed onto it. Are all these disabled?...
PICoHolic
PostPosted: Wed Jul 04, 2007 8:44 am     Reply with quote
Yes of course...
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN, NOPBADEN, ICPRT
setup_adc(ADC_OFF);
set_tris_b(0x00);
Anything else?
10x
PostPosted: Wed Jul 04, 2007 1:48 pm     Reply with quote
1. Post a short, compilable test program that demonstrates the problem.
Show all #include, #use, #device, and #fuses statements.
Show all data declarations.
2. Post your compiler version.
PICoHolic
PostPosted: Thu Jul 05, 2007 12:36 am     Reply with quote
Compiler: 4.029
#include <18F4550.h>
#device adc=8
#use delay(clock=48000000)
#byte PORTA = 0xF80
#byte PORTB = 0xF81
#byte PORTC = 0xF82
#byte PORTD = 0xF83
#byte PORTE = 0xF84
#byte TRISE = 0xF96
// USB
#include <usb_cdc.h>
#define  SetData(X)  PORTB = X
#define  GetData()   PORTB
#bit     SS =  PORTE.0
#bit     SG =  PORTE.1
#bit     RW =  PORTE.2
#bit     DR =  PORTC.2
#define  isSPI()     bit_test(Buff[1],7)
#define  Finalize()  (!bit_test(Buff[1],6))
#define  isREAD()    bit_test(Buff[2],7)
void SetCSR(int16 CSRData)
   PORTD = CSRData & 0xFF;
   PORTA = CSRData >> 8;
   unsigned int8 Buff[132];
   unsigned int8 BuffPointer=0;
   unsigned int8 DataLen=0;
   unsigned int8 i;
   PORTA = 0x00;
   PORTB = 0x00;
   PORTC = 0x00;
   PORTD = 0x00;
   PORTE = 0x01;
   set_tris_a(0x00);
   set_tris_b(0x00);
   set_tris_c(0xFE);
   set_tris_d(0x00);
   set_tris_e(0x00);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_low_volt_detect(FALSE);
   setup_oscillator(False);
   usb_cdc_init();
   usb_init();
   while(!usb_cdc_connected()) {}
   while (TRUE)
      usb_task();
      if (usb_enumerated())
         Buff[BuffPointer++] = usb_cdc_getc();
         if (BuffPointer == 3) // check for data length
            DataLen = Buff[BuffPointer-1] & 0x7F;
         if ((BuffPointer == DataLen + 3) || ((BuffPointer == 3) && (isREAD())))
         {   //end of buffer?
            switch (Buff[0])
               case 0xFF:     // Data <-->
                  if (isREAD())     //read
                     set_tris_b(0xFF); // input
                     RW = 1;
                     if (isSPI())// SPI
                        SetCSR(0x100 | (Buff[1] & 0x3F));
                        SS = 0;
                        for (i=0;i<DataLen;i++)
                           SG = 1;
                           delay_us(3);
                           SG = 0;
                           while(!DR); //wait for DR
                           usb_cdc_putc(GetData());   // send data to pc
                        SS = 1;
                     else        // I2C
                        SetCSR(Buff[1] & 0x7F);
                        SS = 0;
                           SG = 1;
                           delay_us(3);
                           SG = 0;
                        SS = 1;
                  else              //write
                     set_tris_b(0x00); //  output
                     RW = 0;
                     if (isSPI())// SPI
                        SS = 0;
                           //SetData(Buff[3+i]);
                           PORTB = Buff[3+i];      // PROBLEM in RB0 ///////////////////////////////
                           SG = 1;
                           delay_us(3);
                           SG = 0;
                        if (Finalize())
                           SS = 1;
                     else        // I2C
                        SS = 0;
                           SG = 1;
                           delay_us(3);
                           SG = 0;
                        SS = 1;
               case 0xAA:  // Command (reserved)
            BuffPointer = 0;     // reset pointer
            DataLen = 0;         // clear data length
Everything works poerfect except for the lines commented with "// PROBLEM in RB0 ///////////////////////////////"
Shocked
PostPosted: Thu Jul 05, 2007 12:44 am     Reply with quote
I wouldn't call that a short test program.
PICoHolic
PostPosted: Thu Jul 05, 2007 12:53 am     Reply with quote
Dont worry about all the code.
Just the commented one.
10x
PostPosted: Thu Jul 05, 2007 3:15 am     Reply with quote
I would add a couple of things:
CCP2C1
Otherwise CCP2 is multiplexed onto portB
Also note that the USB peripheral is multiplexed onto RB2 & 3, while RB4 is the SPP CS pin. I'd probably explicitly clear SPPEN to ensure this is not causing a problem.
Also, if you want to control the TRIS yourself, and write directly to the port, use #use fast_io(B) otherwise the compiler will still think that _it_ has control of the port direction register, and may override what you are doing.
As a comment, why not use the output_b instruction?.
PICoHolic
PostPosted: Thu Jul 05, 2007 3:29 am     Reply with quote
1- CCP2C1 is added by default:
Configuration Fuses:
   Word  1: 0E24   NOIESO NOFCMEN HSPLL PLL5 CPUDIV1 USBDIV
   Word  2: 1E38   NOBROWNOUT NOWDT BORV20 PUT WDT32768 VREGEN
   Word  3: 8100   NOPBADEN CCP2C1 MCLR NOLPT1OSC RESERVED
   Word  4: 00A1   STVREN NODEBUG NOLVP NOXINST ICPRT
   Word  5: C00F   NOPROTECT NOCPD NOCPB
   Word  6: E00F   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTR NOEBTRB
2- SSPEN is cleared:
....................    setup_spi(FALSE);
10CC:  BCF    FC6.5        <---
10CE:  BCF    F94.7
10D0:  BSF    F93.0
10D2:  BCF    F93.1
10D4:  MOVLW  00
10D6:  MOVWF  FC6
10D8:  MOVWF  FC7
I still have to try the output_b function ..
10x anyway
PostPosted: Thu Jul 05, 2007 4:04 am     Reply with quote
SPPEN, not SSPEN
The latter is the SPI connection. The fmer is the synchronous parallel port CS.
