what the state of TMR0IF ?
JULIEN LAFFITTE
PostPosted: Wed Jul 04, 2007 9:00 am     Reply with quote
hello
if it's possible Wink , i want to know if these commands clear or not TMR0IF: Rolling Eyes
-setup_timer_0(mode)
-set_timer0(value)
-#INT_TIMER0
-enable_interrupts(INT_TIMER0);
-disable_interrupts(INT_TIMER0);
thanks
PostPosted: Wed Jul 04, 2007 12:52 pm     Reply with quote
The only one that will, is the interrupt handler for #int_timer0, unless the 'NOCLEAR' option is used. None of the other instructions will have any effect on the interrupt flag.
JULIEN LAFFITTE
PostPosted: Wed Jul 04, 2007 9:58 pm     Reply with quote
tanks
Neutone
Re: what the state of TMR0IF ?
PostPosted: Thu Jul 05, 2007 10:23 pm     Reply with quote
JULIEN LAFFITTE wrote:
hello
-set_timer0(value)
-#INT_TIMER0
thanks
If you want to load a value to the timer then clear the interrupt then enable the interrupt, you would use:
set_timer0(value);
clear_interrupt(INT_TIMER0);
