ADC inconsistencies
elphi
ADC inconsistencies
PostPosted: Mon Jul 02, 2007 12:33 pm     Reply with quote
I have a little problem, I connected an LCD with a 18f4420 , I just tried to emulate a digital voltmeter.
It works, but with some inconsistencies, I mean, it shows a measure, but it changes in a range of +-70mV, I don't know why, but this behavior is not adequate to my project.
I also measured the same voltage at same time with my digital Multimeter (in parallel), and the voltage never changes in the multimeter but in the LCD it changes.
I tried to put a capacitor in parallel with the ADC pin, but it still varies.
Any help will be well came.
this is may code:
#include <18F4420.h>
#device adc=10
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
//#FUSES XT                       //Crystal osc <= 4mhzUT
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#include <hplcd.C>
#include <stdio.h>
#include <stdlib.h>
#use fast_io(d)
#use standard_io(c)
int16 vi=0;
float va;
#int_EXT
EXT_isr()
#int_EXT1
EXT1_isr()
   set_tris_d(0);
   set_tris_c(1);
   output_c(0xff);
   output_c(0x0);
   setup_adc_ports(AN0|VSS_VDD);
//   setup_adc_ports(AN0|VSS_VREF);
   setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_2);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   enable_interrupts(INT_EXT);
   enable_interrupts(INT_EXT1);
   setup_low_volt_detect(FALSE);
//   setup_oscillator(FALSE);
   setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_OFF);
   //my code
   lcd_init();
   printf(lcd_putc,"\f");
   printf(lcd_putc,"VOLTAGE:");
   while (true)
      lcd_gotoxy(1,2);
      vi=read_adc();
      va=(vi*5/1023.0);
      printf(lcd_putc,"%.6f",va);
Every little thing gonna be alright
PostPosted: Mon Jul 02, 2007 12:47 pm     Reply with quote
#FUSES LVP
You need to fix the problems shown above.
Do you have a low voltage programmer ? 99% of all people have
a high-voltage programmer. In that case, the fuse must be NOLVP.
You have the #use delay() set for one frequency, but you have
the oscillator set to a different frequency.
Look in the A/D section of the 18F4420 data sheet. What clock divisor
does it say to use for 4 MHz operation ?
Where's the line of code to set the channel ? Example:
set_adc_channel(0);
At least two or three of the problems above could be the cause of
your problem.
elphi
sorry
PostPosted: Mon Jul 02, 2007 6:44 pm     Reply with quote
OK, I post a bad version of may software, sorry , the #use delay is 8000000 as in the setting of the internal oscillator.
The datasheet says that I must use an 8TOSC, but I don’t understand that. Does it means some like :
setup_adc(ADC_CLOCK_DIV_8|ADC_TAD_MUL_8);
and sincerely I don’t know what is the channel in the adc.
It’s embarrassing but, i will need more support
PostPosted: Mon Jul 02, 2007 7:27 pm     Reply with quote
Here, in your code, you setup the A/D to use channel 0:
That's why I said you must add this line of code:
set_adc_channel(0);
elphi
ok
PostPosted: Mon Jul 02, 2007 10:23 pm     Reply with quote
Ok, i get it, i made the change, but regarding the other seccion of your answer:
but remember that i am using the 8mhz internal clock.
tnks it advance for your help.
PostPosted: Tue Jul 03, 2007 1:39 am     Reply with quote
That would work. According to the data sheet, the minimum Tad is 0.7 us.
Using the 8 MHz internal oscillator and dividing it by 8 gives you a 1 MHz
Tad clock, which gives a period of 1.0 us. That satisfies the minimum
requirement for Tad.
According to the data sheet, the minimum acquisition time is 2.4 us.
That means you could use ADC_TAD_MUL_4 to set the acquisition time,
because with a Tad of 1.0 us, this would give 4.0 us and it would satisfy
the Tacq requirement. But the ADC_TAD_MUL_8 value would still work.
It's longer than you need, but I doubt if it would make much difference
in the result.
