bit manipulation
Marc
bit manipulation
PostPosted: Fri Jun 29, 2007 8:50 am     Reply with quote
I have 3 registry bits:
ADCONbits.CHS2=1
ADCONbits.CHS1=0
ADCONbits.CHS0=0
How can I define something which contains them so that I can write
CHS=100
and those bits take the values I want
Thank You
kevcon
PostPosted: Fri Jun 29, 2007 9:23 am     Reply with quote
You didn't say what processor you were using, so I wrote this is for the PIC18F65J10.
you should be able to convert it though.
struct {
   unsigned int1 ADON;
   unsigned int1 GOnDONE;
   unsigned int8 CHS : 4;
   unsigned int1 bit6;
   unsigned int1 ADCAL;
} ADCON0;
#locate ADCON0 = getenv( "SFR:ADCON0" )
void main( void )
   ADCON0.CHS = 0b0100;
Marc
PostPosted: Fri Jun 29, 2007 2:12 pm     Reply with quote
Thank you but if I have:
unsigned char ADCON2;
#locate ADCON2=0x0FC0
struct {
unsigned ADCS0:1;
unsigned ADCS1:1;
unsigned ADCS2:1;
unsigned ACQT0:1;
unsigned ACQT1:1;
unsigned ACQT2:1;
unsigned :1;
unsigned ADFM:1;
} ADCON2bits;
#locate ADCON2bits=0x0FC0
without touching this structure, how can I use ADCS=110 ?
future
PostPosted: Sat Jun 30, 2007 5:25 am     Reply with quote
You can set bit by bit.
ADCON2.ADCS0 = 0;
ADCON2.ADCS1 = 1;
ADCON2.ADCS2 = 1;
or
ADCON2 &= 0b11111000;
ADCON2 |= 0b00000110;
Marc
PostPosted: Sat Jun 30, 2007 9:28 am     Reply with quote
Perhaps I can explain.
I need something that modify only three bits and have a name ADCS, I don't know but I think a structure or union that contains those bits
PostPosted: Sat Jun 30, 2007 10:13 am     Reply with quote
Apparently you don't want to use the "dot" syntax to access the bitfield.
Instead, you want to access it with the symbolic name of "ADCS".
You can do this with a #define statement. Use Kevcon's structure
and define a symbolic name for that bitfield. Then access it by that
name in your main program. Example:
#define ADCS (ADCON0.CHS)
ADCS = 0b1010;
Marc
PostPosted: Sun Jul 01, 2007 2:49 am     Reply with quote
So with command
the compiler knows that ADCON0.CHS means ADCON0.CHS0 plus ADCON0.CHS1, ADCON0.CHS2, ADCON0.CHS3 (ADCON0.CHSx) ?
Or it works only in this situation? Because I'm speaking about grouping 3 bits in a structure which contains 8 bits each of them with a name
