stream as function argument
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Thu Jun 28, 2007 4:01 pm     Reply with quote
Does CCS permit to pass a stream (or a pointer to a stream) to a function as an argument? Like this for example
#use rs232(..., stream=one232)
#use rs232(..., stream=two232)
int8
check_send(stream m, // stream to send to
 char* s) // null terminated string to send
 fprintf(m, s);
 return check_sum(s);
// calling code
 iChkSum = check_send(one232, "hello");
 iChkSum = check_send(two232, "world");
Unfortunately, I couldn't make it work?
Read the label, before opening a can of worms.
Neutone
Re: stream as function argument
PostPosted: Thu Jun 28, 2007 10:17 pm     Reply with quote
int8
 fprintf(m, s);
// calling code
I think you could probably write your own using a pointer to the hardware shift buffers. CCS does not support this because it can not work with a software serial port. At the end of the day I think it would be better (easier) to just pass a bit in the function call to switch between ports.
kender
PostPosted: Thu Jun 28, 2007 10:21 pm     Reply with quote
But somehow fputc() and fprintf() take a stream as an argument.
PostPosted: Thu Jun 28, 2007 10:54 pm     Reply with quote
They do, but it's only used at compile-time. If you look at the compiled
code in the .LST file, there is no code inserted which checks a variable
to see which stream to use. The decision is made entirely at compile-
time and fputc() is hard-coded to use the selected stream at that time.
