Long serial timeout
Long serial timeout
PostPosted: Fri Jun 22, 2007 3:37 am     Reply with quote
Have done many searches but couldn't find answer I was looking for.
PIC is 16LF877 4Mhz. Compiler. 3.181
I am using the code below to read in a serial string.
This works fine.
What I want to to be able to time out if nothing is received for about 10 seconds.
All other timeout routines seem to be too short.
Thanks in advance
Steve
#include "C:\PIC_C_Code\Smart Modem\Smart Modem.h"
#include <string.h>
void Get_String2();
void get_string(char* s, int max);
#define MAX_BUFFER 10
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   //Get_Char();
   Get_String2();
   return;
void Get_String2()
  char string[MAX_BUFFER];
    printf("please type a string: ");
    // Wait for a key press
    while(!kbhit(MODEM));
    get_string(string, MAX_BUFFER);
    fprintf(RDTG,"%s",string);
   int len;
   char c;
   --max;
   len=0;
   do {
     c=fgetc(MODEM);
   //  if(c==8) {  // Backspace
   //     if(len>0) {
   //       len--;
   //       putc(c);
   //       putc(' ');
   //       putc(c);
   //  } else
     if ((c>=' ')&&(c<='~'))
       if(len<max) {
         s[len++]=c;
         putc(c);
   } while(c!=13);
   s[len]=0;
Humberto
PostPosted: Sat Jun 23, 2007 9:56 pm     Reply with quote
V3.181 is quite old, I´m not sure if in the Examples folder you have the EX_TGETC.C
program that shows exactly what you need.
Humberto
PostPosted: Thu Jun 28, 2007 2:28 am     Reply with quote
Many Thanks Humberto.
I do have that piece of code.
Was reluctant to use it as I didn't think it would be possible to achieve the 10 seconds I would like?
Is it possible?
(I will play in the meantime)
Thanks again
Steve
Humberto
PostPosted: Thu Jun 28, 2007 6:56 am     Reply with quote
Steve,
With the pointed example, I wish you get the way, how to do it. The program
was used widely and I´m not aware of something wrong using it. Of course you
will need to adapt it to your 10 sec timeout application.
Humberto
kevcon
PostPosted: Thu Jun 28, 2007 7:29 am     Reply with quote
Setup a timer to interrupt every 1ms and count to 10000
voidt main( void )
   unsigned int16 timeOutCounter = 0;
   set_rtcc( SomeValue );
   while( !kbhit( MODEM ) && ( timeOutCounter < 10000 ) );
   if ( timeOut Counter > 10000 ) }
      timeOutCounter = 0;
      ///timout code goes here
   else {
      //kbhit code goes here
#pragma INT_RTCC
void ms_timer( void )
   timeOutCounter++
PostPosted: Thu Jun 28, 2007 8:36 am     Reply with quote
Getting there. Thanks to all.
Just adapting the example code to suit works fine.
newbie_1974
timeout
PostPosted: Thu Jul 05, 2007 12:05 am     Reply with quote
hi, would it be possible to get a copy of your time out code, thanks.
