bulk usb demo
just4ho
bulk usb demo
PostPosted: Sun Mar 25, 2007 11:04 pm     Reply with quote
Hi everybody
I'm writing a PC software for the CCS bulk usb driver. I want to know the driver link name for the API call CreateFile.
(driver link name, _
GENERIC_READ, _
0, 0, _
OPEN_EXISTING, _
FILE_ATTRIBUTE_NORMAL, 0&)
does anybody has an Idea?
embcoder
usb bulk demo MS Visual C++ 6.0 code
PostPosted: Wed Jun 13, 2007 7:20 am     Reply with quote
I don't know Pascal (their source code) as used in the Oscope program.
I'm trying to communicate using the following two sets of code. Although both appear to work at the PC end, the PIC says no go. Its been some time since you posted, so perhaps you've figured this all out and can help me.
Les
// usb.cpp : Defines the entry point for the console application.
#include <stdafx.h>
#include <windows.h>
#include <stdio.h>
int main(int argc, char* argv[])
   FILE* fpointer;
    HANDLE      hCmdInterface;
   char data[512];
   int count;
   char db[2];
   ULONG iRet;
   BOOL fRet;
   db[0] = 22;
   db[1] =   0;
   // METHOD ONE
   hCmdInterface = NULL;
   hCmdInterface =  CreateFile ("CCS USB Demo", // Pointer to the name of the port
                          GENERIC_READ | GENERIC_WRITE,   // Access (read-write) mode
                          FILE_SHARE_READ | FILE_SHARE_WRITE,  // Share mode
                          NULL,         // Pointer to the security attribute
                          OPEN_EXISTING,// How to open the serial port
                          0,            // Port attributes
                          NULL);        // Handle to port with attribute
   fRet = WriteFile(hCmdInterface, db, 2, (ULONG*)&iRet, NULL);
   fRet = ReadFile(hCmdInterface, data, 256, (ULONG*)&iRet, NULL);
   CloseHandle(hCmdInterface);
   // METHOD TWO
   fpointer = fopen("CCS USB Demo", "w+");
   count = fwrite (db, 1, 2, fpointer);
   count = fread(data, 1, 256, fpointer);
   fclose (fpointer);
   //printf("Hello World!\n");
   return 0;
embcoder
Bulk Demo working with MS Visual C++
PostPosted: Thu Jun 14, 2007 10:05 am     Reply with quote
I spoke with Mark in Tech support this morning. The correct name for the USB bulk driver is in the following code:
// t1.cpp : Defines the entry point for the console application.
//#include "stdafx.h"
#include <stdafx.h>
#include <stdio.h>
int _tmain(int argc, _TCHAR* argv[])
   char data[512];
   char db[2];
   ULONG iRet;
   BOOL fRet;
   db[0] = 22;
   db[1] =   0;
   memset(data, 0, sizeof(data));   // zero out the data space
   // ASCII form
   hCmdInterface =  CreateFileA ("\\\\.\\BulkUsbDemoDevice0", // Pointer to the name of the port
   // UNICODE form
   hCmdInterface =  CreateFile  (TEXT("\\\\.\\BulkUsbDemoDevice0"), // Pointer to the name of the port
   fRet = WriteFile(hCmdInterface, db, 2, (ULONG*)&iRet, NULL);   // must write the two bytes first!
   return 0;
This code was written using MS Visual Studio 2005. Mark used the Delphi debugger to step through the CreateFile function in the Oscope program provided with the USB demo kit. Please note that the number of backslash characters is double what was showing in the Delphi code. It's just a 'C' thing.
just4ho
I have made Visual Basic version of Oscope software
PostPosted: Wed Jun 27, 2007 9:23 pm     Reply with quote
I have solved the createfile issue for Visual Basic API and created an application. it's Visual Basic version of Oscope software. I'm sure many people were waiting for Visual Basic version of Oscope software. So I'll make it available for them.
Create a form and include 1 picturebox, 4 command button, 1 textbox and 1timer.
Then copy following code.
It works with ex_usb_scope.c
Option Explicit
Private Const GENERIC_WRITE = &H40000000
Private Const GENERIC_READ As Long = &H80000000
Private Const INVALID_HANDLE_VALUE As Long = -1
Private Const OPEN_EXISTING As Long = 3
Private Const FILE_ATTRIBUTE_NORMAL As Long = &H80
Private Const MAX_PATH As Long = 260
Private Declare Function CreateFile Lib "kernel32" _
   Alias "CreateFileA" _
  (ByVal lpFileName As String, _
   ByVal dwDesiredAccess As Long, _
   ByVal dwShareMode As Long, _
   ByVal lpSecurityAttributes As Long, _
   ByVal dwCreationDisposition As Long, _
   ByVal dwFlagsAndAttributes As Long, _
   ByVal hTemplateFile As Long) As Long
Private Declare Function ReadFile Lib "kernel32" (ByVal hFile As Long, _
   lpBuffer As Any, ByVal nNumberOfBytesToRead As Long, _
   lpNumberOfBytesRead As Long, ByVal lpOverlapped As Long) As Long
Private Declare Function WriteFile Lib "kernel32" ( _
  ByVal hFile As Long, lpBuffer As Any, _
  ByVal nNumberOfBytesToWrite As Long, _
  lpNumberOfBytesWritten As Long, ByVal lpOverlapped As Long) As Long
Private Declare Function CloseHandle Lib "kernel32" _
  (ByVal hFile As Long) As Long
Dim hFile As Long
Dim bytArr(513) As Byte
Dim outArr(8) As Byte
Private Sub Command1_Click()
    hFile = CreateFile("\\.\BulkUSBDemoDevice0", _
                         GENERIC_WRITE Or GENERIC_READ, _
                         0, 0, _
                         OPEN_EXISTING, _
    Timer1.Enabled = True
End Sub
Private Sub Command2_Click()
    Timer1.Enabled = False
    CloseHandle hFile
End Sub
Private Sub send_data()
    Dim lSuccess As Long
    Dim lBytesToWrite As Long
    Dim lBytesWritten As Long
    lBytesToWrite = 8
    lSuccess = WriteFile(hFile, outArr(0), _
                        lBytesToWrite, lBytesWritten, 0)
End Sub
Private Sub Command3_Click()
    If outArr(1) > 1 Then
        If outArr(1) <128> 1 Then
        outArr(1) = outArr(1) / 2
    End If
    send_data
End Sub
Private Sub Form_Load()
    outArr(1) = 1
                         0, 0, _
                         OPEN_EXISTING, _
    If hFile = -1 Then MsgBox "Could not connect to USB driver"
End Sub
Private Sub Timer1_Timer()
    Dim sc As Long
    Dim i As Long
    Dim lBytesRead As Long
    Dim lBytestoRead As Long
    Text1.Text = outArr(1)
    lBytestoRead = 512
    lSuccess = ReadFile(hFile, bytArr(0), _
                      lBytestoRead, lBytesRead, 0)
    sc = 511
    Picture1.Cls
    Picture1.Scale (8, 255)-(sc, 0)
    Picture1.DrawWidth = 1
    For i = 8 To sc Step 1
    Picture1.Line (i, bytArr(i))-(i + 1, bytArr(i + 1)), &H80FF&
    Next i
End Sub
kalle
PostPosted: Sat Mar 15, 2008 3:43 pm     Reply with quote
Hi @ll,
could anybody please send me the usbdemo.sys driver? I searched the whole day, but did not find find it ...
Thank you very much in advance.
Email: e-techniker80@gmx.de
Best regards from Germany
P.S. Your VB6 Example is not working properly. There is a "End If" missing ...
